Help!!!
Old May 9, 2019 | 06:12 PM
typeS219's Avatar
Unhappy Help!!!
So i am the original owner of my 2007 acura tl type s with 80,000 mile. MANUEL TRANNY. A couple years back there was a recall cause 3rd gear would sometimes pop out. so acura dealer fixed it and everything was good. recently got timimg belt, water pump, and oil pump replace cause i plan on running this thing to 200k miles. SO, i recently noticed oil leaking from underneath the car. i thought it was the oil pan, and it was not sealed correctly. i bought it to my mechanic, and he gave me bad news. my transmission is leaking oil. Has anyone had a problem like this? if so what was their plan of action? Once again this is a manuel transmission, any advise would be of great help!
thanks
Antonio
Old May 9, 2019 | 06:13 PM
where is it leaking from? the mechanic should be able to tell you that. Is it the rear main seal?
Old May 9, 2019 | 06:24 PM
TVL65's Avatar
I have 160,000 on my 07' TLS. My Trans (AT) was working fine, started leaking last year but was only slight. Within the last few months it got worse, far worse, like fresh fluid on the pavement every time I parked. It's a shame because it was working perfectly fine. I researched online for used but for $800 I'm sure they were abused or probably had issues. There were rebuilt ones for $1500 + but I have no idea who rebuilt it and exactly what was done or if they were rebuilt correctly? I bit the bullet and had dealer install a re-manufactured Trans, For the trans & labor it came to $5200. BUT I know it was completely torn apart & rebuilt by qualified Techs. Its got a warranty from Acura for 3/36,000. There are Trans shops here in NJ that could have rebuilt it for probably $4,000 but I read horror stories online, like not standing behind their work and problems. Level 10 shop has many bad reviews. Eventually your leak will get much worse. BTW if you do the trans be sure to replace rear main seal too while in there. GOOD LUCK!
Old May 9, 2019 | 06:25 PM
typeS219's Avatar
so my mechanic does not work with transmissions. he is an honest guy and told me he does not want to take the chance of pulling it out. he said however is seems to be leaking from the front...i dont know what to do...i know an acura dealer will rape me..im just looking to see if anyone has endured a problem like this.
Old May 9, 2019 | 06:29 PM
well you're going to have to be our eyes, we won't be able to tell you where the leak is from the internet. Take a look and see if it's a transmission line or the lines going to the radiator or something..
give us a bone here!
Old May 9, 2019 | 06:30 PM
typeS219's Avatar
I thought it would be that much. so i might have to sell my baby :''''''''''''''(
Old May 9, 2019 | 06:32 PM
typeS219's Avatar
im gonna have to give my mechanic a call and see if he could give me more detail....i wish i was more knowledgeable with thus stuff... sorry guys lol
Old May 9, 2019 | 06:58 PM
nfnsquared's Avatar
Originally Posted by typeS219
..SO, i recently noticed oil leaking from underneath the car....
How much?
From your other posts, sounds like it may be a rear main seal leak. Have you every replaced your PCV valve? Do a search, might be a simple $25 fix....
Old May 9, 2019 | 08:11 PM
typeS219's Avatar
How much?
Honestly not that much...id say a couple drops a day(the siz of a quarter) id see on my driveway...so you think it might be rear main seal leak? Where is the exatcly located? Because i can see the oil coming from the front of the car...near the oil pan area
but just looked up pcv valve replacement..no i have never changed..but would that initiate some sort of leaking?
Old May 9, 2019 | 09:07 PM
nfnsquared's Avatar
Yes, if it's blocked or stuck shut causing over-pressurization of the crankcase.
Front of car? Not the main seal then. Check your front valve cover and below it.
Also could be oil pump (fairly common) or vtec solenoid.
Did your mechanic say it was transmission oil or engine oil?
Old May 10, 2019 | 07:53 AM
Jackass's Avatar
MT...there are no lines going anywhere.
My guess is it is the normal weeping of engine oil from either the oil pan, oil pump, or rear main seal. Mine has been "weeping" for several years that leaves nickel size spots randomly on my garage floor. Not nearly enough to worry about and spend money on. I will worry about it in about another 2 years when the next TB service comes due.
Old May 10, 2019 | 11:14 AM
Shows how much i know about MT's
Old May 10, 2019 | 12:18 PM
whitetiger5's Avatar
I've always wanted to use this...
Send some pics! If we can see where the oil is leaking from then we could provide you with some more accurate feedback as to where you should start looking.
It will certainly put your mind at ease to know more clearly what the issues (and the severity).
Old May 10, 2019 | 06:13 PM
typeS219's Avatar
will get some pics up soon...car is at the mechanic and will be getting back this weekend... thanks for the feedback guys
Old May 10, 2019 | 09:55 PM
truonghthe's Avatar
or you can sell the car to m8....
I would have other mechanic look at it before you conclude with the verdict that the transmission is leaking, per half take it to shop that specialize in transmission.
Old May 10, 2019 | 10:14 PM
horseshoez's Avatar
Latent car nut
My take on this thread and on your issue is the rear main seal is FAR more likely the culprit than the transmission. When you say the leak is coming from near the rear of the oil pan I start thinking that even more. The only manual transmission I've ever seen leaking from the main input shaft caused the clutch to start slipping; if your's isn't then that's just one more indication the rear main seal is the issue. FWIW, last year when I had my clutch replaced, I had the rear main done, not because it was leaking, but it was an extra $50 since the transmission was already out.
Old May 10, 2019 | 11:05 PM
nfnsquared's Avatar
... When you say the leak is coming from near the rear of the oil pan....
Huh?
Old May 10, 2019 | 11:09 PM
horseshoez's Avatar
Latent car nut
Huh?
I interpreted Post #9 as meaning near the rear of the engine oil pan (meaning the left side of the engine between the engine and the bellhousing); I could be wrong, but until more definitive information comes our way, that stands as my current understanding of the issue.
Old May 11, 2019 | 08:49 AM
t-rd's Avatar
All you have to do to see if there is a rear main seal leak is to remove the inspection cover. 2, 10mm bolts. It's not a monumental task to identify that. It is a huge task to change out the rear main seal. So if you want to pay for that job, then might as well change out the clutch at the same time. If you want a new TL, that's fine also. $500 ~ $800 monthly loan for years. You pretty much pay for that same job in a matter of months, but for that new car, you have to pay that for YEARS.
Old May 11, 2019 | 09:09 PM
typeS219's Avatar
This is what the mechanic said...still havent got the car back but ill see if he can throw it on the lift and take some pics...he says the case looks like it might be cracked...fml
will keep you updated
Old May 12, 2019 | 12:23 AM
nfnsquared's Avatar
1. How does he know that an auto-adjusting clutch is worn and about to go?
2. That sucks if the case is leaking. I'd go back to the dealer and complain.
Old Aug 17, 2019 | 08:04 PM
typeS219's Avatar
sooo...here is an update....back in 2009 I had the 3rd gear recall done by Acura (manual transmission)...they did all the work and car ran nice....so this leaking im am getting is coming from my transmission case... when they took the tranny out and went to re-seal it, they did not do a good job. that seal is now leaking, causing trans fluid to leak...I called Acura and said nothing they can do...I have a friend that is a Honda mechanic and he was gonna take tranny out, replace clutch, and reseal for about 3grand...I think that is the route I am going to take..does anyone have any recommendations for preventive matienence when he takes the tranny out? real main seal etc??
thanks
Antonio
Old Aug 17, 2019 | 10:11 PM
horseshoez's Avatar
Latent car nut
thanks
Antonio
Definitely rear main; while I was in there I did the pressure plate (highly-HIGHLY recommended) and performed the CDV delete. Also, with the transmission out and the engine supported from the bottom, replacing all six engine and tranny mounts becomes a relatively trivial job.
Old Aug 18, 2019 | 12:55 PM
truonghthe's Avatar
while you have the transmission out, IF its was mine TL I would replace the following original components
1. Steering rack and pinion (IF you found leak) with new inner and outer tire rods.
2. Three motor mounts and transmission mount(s).
3. Rear main seal and new flywheel with clutch.
Old Aug 18, 2019 | 04:34 PM
typeS219's Avatar
im sorry what is the cdv delete?
Old Aug 18, 2019 | 04:36 PM
typeS219's Avatar
def doing the rear main seal, flywheel, clutch, and solenoids
for the motor mounts and tranny mounts, should I check to see if there in good condition? or just change anyway?
I saw they where a bit expensive
Old Aug 18, 2019 | 04:46 PM
horseshoez's Avatar
Latent car nut
Clutch Delay Valve delete; this give crisper shifts when romping on it.
Old Aug 18, 2019 | 08:05 PM
typeS219's Avatar
gotcha....will mention this to my mechanic when we discuss the plan of action
Old Aug 19, 2019 | 12:31 PM
truonghthe's Avatar
change it, the motor mounts is notorious for getting busted around 80k-100k miles. Three mounts is the biggest ticket item but you will save a ton on labor since the motor has to come out anyway.
Old Aug 21, 2019 | 03:02 PM
typeS219's Avatar
Could you guys recommend a good brand of motor and tranny mounts? I see the oem are pretty expensive and found others a bit cheaper but dont know if there reputable
Old Aug 21, 2019 | 04:06 PM
horseshoez's Avatar
Latent car nut
OEM. Period, full-stop, the end.
Old Aug 21, 2019 | 04:50 PM
EvilVirus's Avatar
thanks
Antonio
So your friend is only replacing the clutch and rear main seal....for $3k? Is he rebuilding the tranny too?
Old Aug 21, 2019 | 09:05 PM
WDPanda's Avatar
3 grand and friend don't go together.
You can get a used transmission installed for about a grand. Wtf.
Old Aug 21, 2019 | 10:07 PM
typeS219's Avatar
New clutch flywheel solnoids and both rear brake calipers...3k for parts and labor
Old Aug 21, 2019 | 10:08 PM
typeS219's Avatar
Parts and labor...flywheel itself is 900
i dont want a used tranny and someone’s problems
Old Aug 21, 2019 | 10:10 PM
csmeance's Avatar
You can go aftermarket for WAY cheaper....
Old Aug 21, 2019 | 10:11 PM
typeS219's Avatar
Gotcha
Old Aug 21, 2019 | 10:50 PM
typeS219's Avatar
I not going cheap on the transmission..was looking to save money other places such as the motor mounts but now its looking like all oem
Labor not cheap where i live(NY)
Old Aug 21, 2019 | 10:53 PM
csmeance's Avatar
I understand your hesitation, but folks are running aftermarket flywheel and clutch with no issues and pumping out some serious power though the rotrex kits.... Trying to save you some $$$ Innovate 75A new style engine are really good for performance seekers... OEM can be found way cheaper such as DENSO parts rather than buying the same DENSO part though the dealer. Also make sure that the case is good and not cracked, I've seen a cracked one in miami happen and spill fluid everywhere.
Old Aug 21, 2019 | 11:12 PM
typeS219's Avatar
I know i see the aftermarket clutch and flywheels out there but ive herd bad stories about them too. I just want to be safe cause i def dont want to have the tranny pulled out twice....as for the case, it is definitely not cracked, however leaking from the seam because the asshole from acura who did the recall didnt do it well....my clutch is in good condition, meaning it still grabs and doesn’t slip but i figured since its out, mind as well put a new one in to make this thing run to 200k
