HELP-'05 TL alternator replacement
Old Jul 6, 2015 | 04:51 PM
Reann206's Avatar
6th Gear
so the alternator is out in my 2005 acura TL and im not sure how to go about replacing it. I have had to do it in other vehicles but never an acura, im a girl and still kinda learning the ropes obviously. I know I have to jack up the passenger side and remove the front tire but from there, im lost. what belt do I remove? what tools do I need? please help me, im stranded and on my own! Hell if anyone who helps me is near by, ill make them an amazing lasagna and deliver once i finish my car lol.
thank you all!
Old Jul 6, 2015 | 04:54 PM
You're in the wrong forum. You're looking for the 3G forum.
In this forum, the correct way to fix it would be to buy a new car.
I'm sure a mod will be by soon to move it for you.
Old Jul 6, 2015 | 04:57 PM
Reann206's Avatar
6th Gear
I appreciate it, not sure what im doing on here. guess earching for hope lol. thanks!
Old Jul 6, 2015 | 06:42 PM
Ron A's Avatar
Administrator
Moved to 3G TL Problems & Fixes.
Welcome to the forums.
Old Jul 6, 2015 | 08:10 PM
rlineberg's Avatar
5th Gear
Lasagna huh? What's your zip code?
Old Jul 6, 2015 | 09:54 PM
AZuser's Avatar
_
thank you all!
These might help.
From: https://acurazine.com/forums/problem...nt-diy-925472/
Originally Posted by Turbonut
Make sure you have the anti theft code for radio/nav
Disconnect neg terminal, disconnect pos terminal
Disconnect fan motor connector and A/C clutch connector, then remove coolant reservoir
Remove 2 bolts and loosen bolt, then remove the A/C condenser fan shroud assembly
Remove drive belt
Disconnect alt connector and blk wire from alt
Remove bolt securing the harness bracket
Remove mounting bolt and alt bracket bolt, then remove alt.
Old Jul 6, 2015 | 11:01 PM
Reann206's Avatar
6th Gear
I greatly appreciate it, unfortunately neither of those are where mine is located, I was just hoping to get some advise from someone who had already done it because I'm not sure how to remover the belt and exactly what else I need to remove aside from the tire. I do appreciate your help though.
Old Jul 7, 2015 | 01:30 AM
UA6kid's Avatar
I had to replace my alternator the other day. Its pretty simple actually, just start by removing the negative on your battery.
After that you'll need to remove your sep belt, the way to do that is to find the tensioner and with a rachet or a wrench you push it back towards the windshield that should release some tension on the belt.
With the tension released, slip the belt off where the alternator pulley is. You might need a second person to help you unless you can hold back the tensioner with one hand and slip the belt off with the other.
After you got pass that part, you'll need to undo the positive connection to the alternator which is behind the black rubber thing. Undo that bolt and undo the negative connection to the alternator. With that all done just remove the 2 bolts holding the alternator in place.
Replace with new alternator and bolt everything back up and slide the sep belt back on. Connect battery back together and you should be done.
Old Jul 7, 2015 | 01:32 AM
UA6kid's Avatar
You shouldn't need to take the tire off btw
Old Jul 7, 2015 | 02:39 AM
Reann206's Avatar
6th Gear
Omg thank you so much, the only but of a video I could find for the 2005 showed them take off the tire. But other yrs were showing to do it from above the car. You're a life saver. I appreciate it!
Old Jul 7, 2015 | 07:13 PM
UA6kid's Avatar
Becareful with the tensioner if you're using a rachet and socket or just a wrench cause if you slip it could snap back at a lot of force. There's a special tool for it if you wanna look into that
Old Jul 8, 2015 | 01:12 PM
Reann206's Avatar
6th Gear
I really appreciate it! Is yours a 2005 as well?
Old Jul 12, 2015 | 07:28 AM
UA6kid's Avatar
No, I have an 07 :[
csmeance
Jan 7, 2026 06:25 PM
chrisr
Dec 4, 2015 02:17 AM
01CLOwner
Oct 9, 2015 01:07 PM
iCrap
Sep 11, 2015 06:21 PM
Phambam12
Sep 6, 2015 06:57 PM
