HELP-'05 TL alternator replacement
so the alternator is out in my 2005 acura TL and im not sure how to go about replacing it. I have had to do it in other vehicles but never an acura, im a girl and still kinda learning the ropes obviously. I know I have to jack up the passenger side and remove the front tire but from there, im lost. what belt do I remove? what tools do I need? please help me, im stranded and on my own! Hell if anyone who helps me is near by, ill make them an amazing lasagna and deliver once i finish my car lol.
thank you all!
thank you all!
thank you all!
thank you all!
From: https://acurazine.com/forums/problem...nt-diy-925472/
Make sure you have the anti theft code for radio/nav
Disconnect neg terminal, disconnect pos terminal
Disconnect fan motor connector and A/C clutch connector, then remove coolant reservoir
Remove 2 bolts and loosen bolt, then remove the A/C condenser fan shroud assembly
Remove drive belt
Disconnect alt connector and blk wire from alt
Remove bolt securing the harness bracket
Remove mounting bolt and alt bracket bolt, then remove alt.
Remove drive belt
I greatly appreciate it, unfortunately neither of those are where mine is located, I was just hoping to get some advise from someone who had already done it because I'm not sure how to remover the belt and exactly what else I need to remove aside from the tire. I do appreciate your help though.
I had to replace my alternator the other day. Its pretty simple actually, just start by removing the negative on your battery.
After that you'll need to remove your sep belt, the way to do that is to find the tensioner and with a rachet or a wrench you push it back towards the windshield that should release some tension on the belt.
With the tension released, slip the belt off where the alternator pulley is. You might need a second person to help you unless you can hold back the tensioner with one hand and slip the belt off with the other.
After you got pass that part, you'll need to undo the positive connection to the alternator which is behind the black rubber thing. Undo that bolt and undo the negative connection to the alternator. With that all done just remove the 2 bolts holding the alternator in place.
Replace with new alternator and bolt everything back up and slide the sep belt back on. Connect battery back together and you should be done.
chrisr
Dec 4, 2015 02:17 AM
