heated seats light dont work plz helpp
Old Oct 31, 2007 | 06:40 PM
maxls00's Avatar
hey guys,i just purchased a 04 tl and i noticed that the passanger side heated seat light wont work.the heated seats work fine but the night light wont turn on.anyone has same promblem?
Old Nov 1, 2007 | 05:15 AM
ewbuster's Avatar
I also have a 04 TL and have the same problem. Could it be a fuse or wires in the center console?
Old Nov 1, 2007 | 07:06 PM
Brett2's Avatar
6th Gear
If the heat works but the light does not, bad bulb most likely.
Brett
Old Nov 1, 2007 | 07:28 PM
JimiThng's Avatar
bad bulb BUT how do you replace it?
Old Nov 2, 2007 | 11:17 PM
Kumbano1's Avatar
7th Gear
to fix..
First you need to get the bulb from the dealer. Then you have to remove the center storage console. The member by the name 'rets' posted how to remove console. Its here: https://acurazine.com/forums/showpos...42&postcount=5. Slide the console toward the rear and you will see your two heated seat switches. Disconnect the connector for the switch you will be changing the bulb on. Then peel off the silver sticker. Be careful where you place it because you will have to re-use it. Get a small flat tip screwdriver and turn the blue socket counter-clockwise and wiggle it out. Install the new bulb and turn the socket clockwise till you feel the socket is snug inside. Paste the silver sticker back over all three sockets and give it a good rub to make sure its secure. Connect back the connector and put ur park lights on. The switch should now illuminate. And just put back your console.
Old Nov 2, 2007 | 11:26 PM
Kumbano1's Avatar
7th Gear
i forgot to mention that after you slide your console to the rear, you should take out the cup holder. The cup holder is held in place by three gold screws. This will give you more space. And on 'rets' post you would just need to refer to page 20-77 to remove console.
Old Nov 3, 2007 | 09:57 AM
maxls00's Avatar
thanx alot for the help guys,im going to work on this today.seems complicated,i hope i dont break any clips lol. does the VSA button supposed to iluminate also on the 04 tl???
Old Nov 3, 2007 | 10:38 AM
annaie1's Avatar
This seems pretty complicated. I have the same problem. Even though its annoying, the time and effort required isn't worth it. Anyhow, it should be covered by the factory warranty, so next time you get the car serviced, you could have the dealer do it.
Old Nov 4, 2007 | 07:40 PM
timmahh's Avatar
it's me, Alan Rickman.
Just to make sure everyone is clear... the "ON" indicator lights up; there's an amber (should be an LED and it shouldn't burn out) next to LO and HI on each switch, however the switch itself does NOT light up at night like the rest of the buttons on the TL.
Old Nov 8, 2007 | 07:19 AM
blueracer17's Avatar
Timmahh,
They are not LED's, and they do burn out, a lot. I replaced all of the steering wheel lights, seat heat, and all of them on the instrument cluster (the 4 switches up there). It's not difficult, but if they were LED's it wouldn't be a problem. Acura went on the cheap on these lights IMO.
Eric
Old Nov 15, 2007 | 05:10 AM
aradagebeya's Avatar
Ok, My Acura Loving' peers out there...... this is how I changed my interior steering wheel lights (Bulbs...) in my 2004 ACURA TL
- You HAVE to remove the AIRBAG to change any of the bulbs on the steering wheel.... (pictures below)
Here are the steps....
1. You first have to remove the negative from the battery (unhook the battery)
2. You then have to remove the airbag plug from under the steering wheel. There is a compartment on the bottom of the steering you need to open and remove (separate) the yellow plugs in it
3. Unscrew the two screws (THE BIG HOLES) on both sides of the airbag (THIS IS THE TOUGHEST PART OF THE WHOLE EXERCISE)
4. Once you're done... the airbag should come loose and then depending on which bulbs are out...(the Cruise Control lights on the right OR the Radio volume and channel station control light) you can unscrew the silver unit from the back of the wheel and once that Unit comes loose it will pull out .... you flip it over and change whichever bulb is out....!
Then do everything you did in reverse and iput it back together.....
PICTURES BELOW.....
HOPE THIS HELPS MY FELLOW ACURA LOVIN' PEERS OUT THERE....!!!!!!!!!!!!!!! DONT HESITATE TO FLASH OR HONK WHEN YOU SEE ME OUT THERE.....!!!!!!
BE CAREFUL NOT TO FORCE ANYTHING COZ IT WILL BREAK.... IF YOU UNSCREW IT IT SHOULD COME OUT EASILY....
AGAIN... DO NOT FORCE ANYTHING....!
ALL THE BEST!!!!!!!!!!!
Old Nov 27, 2007 | 06:20 AM
HERE ARE THE BULBS!!!!!! HOPE IT HELPS OUT
Old Nov 30, 2007 | 02:14 PM
vinnier6's Avatar
nice write up aradagebeya....thanks for taking the time to post pics along with the write up....
Old Aug 12, 2009 | 01:57 PM
nex1685's Avatar
8th Gear
thank you just trying to do the bulbs this will help
Old Oct 12, 2009 | 04:43 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
im gona try and fix it...do u know the part number for the bulb?
Old Oct 13, 2009 | 01:58 PM
eddiebeltoe's Avatar
2004 AM TL.......
x2
Old Oct 13, 2009 | 09:17 PM
usapierre's Avatar
3rd Gear
nice job - kinda freaked out but want to try it
Old Feb 16, 2019 | 08:22 AM
Hollywood3283's Avatar
I can’t get steering wheel bulbs out and don’t want to force them this is what I did with mine ...(long story) someone destroyed my steering wheel when trying to steal my car so I had to get creative with my control buttons and actually removed them without taking the airbag out just have to get the right side first then the left and be patient
Old Feb 16, 2019 | 08:25 AM
Feb 25, 2020 09:57 AM
theinsvnity
Sep 10, 2015 10:22 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
truonghthe
Sep 7, 2015 11:17 PM
