GM Synchromesh Fluid Fix....
Old May 21, 2009 | 06:22 PM
Ramrodthrusterpuppy's Avatar
Y'know I'm typically extremely skeptical about "magic in a bottle" fixes, but my 3rd gear crunchiness was getting more irritating as time went on.
After reading about the magic of the GM fluid, I said to myself, "What the hell, give it a shot...it's a relatively inexpensive possible fix. Not everyone who raves about it on the forums can be wrong....right?"
So I went out and bought 3 litres of the stuff (@ $18 CAD per litre), drained the old, put in 2.3 litres of the new, went for a quick spin...not expecting much of a difference. Well, I have to say that I'm pleasantly surprised....nay, shocked at the difference! The shifting seems more fluid, smooth....no more 3rd gear notchiness, same goes for the other gears! Frankly, I'm amazed.
So for all those skeptics out there....I was one of you, give this fix a shot! It works!
Old May 21, 2009 | 06:24 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Get 4 more bottles and flush out the whole thing!
Old May 21, 2009 | 06:26 PM
Another case, another fix: GMSMTF-FM FTW! (100% success rate, as far as I know)
Old May 21, 2009 | 06:30 PM
Huh?
It only holds 2.5 litres......not quarts, remember we're metric up here.
Old May 21, 2009 | 06:34 PM
I'm saying to repeat the process 2 more times. That way, you can eliminate all of the old Acura fluid.
Old May 21, 2009 | 06:41 PM
Ah...gotcha!
I'll run it for awhile and maybe perform another flush/refill. I doubt that the little, if any, Acura fluid that's in there mixing with the GM will have a detrimental effect.
Again, I'm just amazed that there's such a dramatic difference!
Old May 21, 2009 | 06:42 PM
Originally Posted by Ramrodthrusterpuppy
Ah...gotcha!
Old May 21, 2009 | 08:36 PM
JwongTLS's Avatar
yes acura should use this for all their 6MT
Old May 22, 2009 | 02:31 AM
anx1300c's Avatar
I'm a believer. It's like a new gearbox in a bottle. Or a new gearbox in three bottles I guess.
Old May 22, 2009 | 03:02 AM
JwongTLS's Avatar
It's like a new tranny!!
Old May 30, 2009 | 09:21 PM
g2teg's Avatar
I had the same problem in my 5th gen prelude, it had a 5th gear grind which was common on those cars. I drained the fluid and put in the synchromesh and it cured it. it came back after a while and I just did the same flush and fill and it fixed it again.
SidhuSaaB
May 30, 2020 12:40 AM
spudweb
May 22, 2016 02:39 PM
LeVeL
Oct 18, 2015 04:19 PM
hpfiend
Sep 27, 2015 06:59 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
