Front Seat-Back assembly
Old Mar 29, 2012 | 10:15 AM
av2600's Avatar
the back of the seat on my 08 tl-s has come loose at the bottom it just sort of flaps around. I havent found a way to secure it, does anyone know what parts i'll need to get it done? I think it may be part 38 but i'm not sure.
I removed the seat back compeltely by sliding it up and off the seat. nothing on it appears to be broken
Thanks!
Old Mar 29, 2012 | 11:51 AM
Bearcat94's Avatar
AZ Community Team
There is a TSB. If under warranty the dealer will do it for free.
Below is a link to the TSB page. You must follow the instructions at the top of Post #1 to access TSB's. Look for TSB# 08-008.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
You can also look at this thread: Front Seat Back Clips AUGH!!!
Old Apr 5, 2012 | 06:33 AM
midnightcivic's Avatar
Sex Bom Omb
So if car is not under warranty, pretty much have to fix it ourselves? Looks pretty easy, thanks for PDF
Old Apr 14, 2012 | 06:09 PM
ds03's Avatar
Easy fix for this... get a couple of large plastic cable ties (12"+, any hardware store will have them) and loop through holes in the seat frame & the metal rod in the seat back section. Pull it tight to lock in place and cut off the excess. If you ever need to access the seat just clip the ties from the bottom and repeat to secure again. Hope this helps.
Old Jul 31, 2012 | 10:11 AM
VQPower37's Avatar
hey all,
i am having this same problem with my 2007 tls, i have the zip ties, but i cannot seem to find the spot that you guys are wrapping the zip tie around on the seat back. can someone post a photo or give me a description of what im looking for on the seat back. i would take the entire cover off, but i am afraid it will not stay on tight like the bottom part, so i have been looking at it from a side angle which is why i am probably not able to see it
Old Jul 31, 2012 | 10:31 AM
ds03's Avatar
Look for the metal pieces on each side (inside the seatback panel, bottom). Could be part of the spring for the magazine holder or hindge, don't remember exactly. Anyway, you can loop around that metal part and nothing will show on the outside once you cut off the excess. On the seat itself there were holes close by in the frame to loop through.
Old Jul 31, 2012 | 10:34 AM
ds03's Avatar
Oh, and I'd remove the panel so you can easily see it first. If your bottom clips are already broken you can just slide the panel up then off. It won't make it any looser later. Once you have the ties on it will be good and tight again.
Old Jul 31, 2012 | 03:25 PM
VQPower37's Avatar
thanks for the response ... i just went ahead and did that and it did definitely help to remove it so i could see what was going on, i feel like its a 9 out of 10 fix though, it still a little shaky, but it looks better at first glance, is that how u guys felt about it?
Old Jul 31, 2012 | 04:07 PM
ds03's Avatar
Mine was as tight as when the clips were in place, like new. Maybe you didn't pull the ties in as much as you could? If you're using long enough ties (12"+) you should be able to pull them from the bottom of the seat pretty tight.
Old Jul 31, 2012 | 04:42 PM
VQPower37's Avatar
ok i think i might have looped them around the wrong thing im gonna cut them and go at it again ... thanks for the response
Old Jul 31, 2012 | 05:15 PM
VQPower37's Avatar
did it again ds03 ... thanks this time i got it on and ziptied it really tight, its holding on tighter than the factory install on my passenger seat ... im thinking i should just pull it off and zip tie that side as well ... thanks for the help
Old Aug 1, 2012 | 06:58 AM
ds03's Avatar
No problem. Glad it worked for you.
Heyzuez20
Oct 14, 2015 07:18 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
theinsvnity
Sep 10, 2015 10:22 PM
08 NBP TL
Sep 8, 2015 08:49 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
