Front & back motor mount thread stripped
Old Dec 4, 2019 | 05:13 PM
xLiquidWolf's Avatar
Ok so long story short
the threads that goes into the engine block is stripped badly.... what are some permanent fixes? I took it to a shop and they said it might be cheaper if I just get a whole engine than taking it to a machine shop...
What are some alternative that don't involve dropping the engine?
Old Dec 4, 2019 | 06:46 PM
helicoil
Old Dec 5, 2019 | 06:42 PM
csmeance's Avatar
helicoil or timesert to fix the threads. Or you can have a mechanic retap the threads a size larger
Old Dec 5, 2019 | 07:24 PM
t-rd's Avatar
If you are talking about the top of the mount where it goes into the engine side, the engine side is an aluminum bracket that's bolted to the block with 3 bolts. They can be removed independently of the block and changed out.
Old Dec 5, 2019 | 08:12 PM
Do you know the timesert size that im going to need? I got the helicoil full kit but i rather slip in there some timeserts instead
Old Dec 6, 2019 | 04:51 PM
csmeance's Avatar
Look at the factory thread size and upsize!
bdtl
Jun 12, 2016 07:52 PM
UTAH TSX
2G TSX Performance Parts & Modifications
Oct 9, 2014 06:47 PM
Miloman5
May 16, 2006 12:32 PM
