Forgive a new guy
Forgive a new guy
guys, i apologize, ive only had my car for 4 months and its my first foreign car. so far i love it!
please answer me this though, last night a service soon light came on...it said "SERVICE DUE SOON A1" what does that mean? and how do i get rid of this warning light....obviously after i fix or repair everything it needs.
i'm sure this is dumb but i couldnt find a definition when i did a search.
A1 is oil change and tire rotation.
MMkay.
^that.
Sometimes ,you will see a "B" vs an "A" on your TL.when you go to the dealer, its billed differently and also requires different procedures (fluids,grease hinges,underbody inspection etc for B)
Followed by a number:
Service 1: Tire Rotation
Service 2 : Engine Air Filter and Cabin Air Filter Replacement
Service 3: Transmission Fluid Drain/Fill, Check CV Boots
Service 4:Spark Plugs,T/Belt,Water Pump, valve clearance adjustment..
Service 5:Cooling system Test and Flush
You may also see this : A123 ( Means you need a Service A1, 2, & 3.
Registered but harmless
Received 1,150 Likes
The owner's manuals (explaining all the service codes, how to reset them, etc.) and navi manuals can be reviewed on-line through the link at the 3G TL Service Dept/Garage at section iii) here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-service-department-aka-garage-questions-answers-check-here-first-553557/.
Welcome to AZ.
I'm not sure the 3G TL is a "foreign car," as it was designed and assembled in Ohio, but with enough foreign parts that it might not be a domestic car either.
The owner's manuals (explaining all the service codes, how to reset them, etc.) and navi manuals can be reviewed on-line through the link at the 3G TL Service Dept/Garage at section iii) here: https://acurazine.com/forums/showthread.php?t=553557.
Welcome to AZ.
Welcome to AZ.
Lol. Wherever you take it to to change the oil, will most likely reset it/turn it off for you. If you're changing the oil yourself, look it up on here or in your manual.
TLicious Type S
Welcome to AZ.
Welcome to AZ.
OculiAquilae
11-19-2018 02:24 PM
