Power steering loud
Old Sep 25, 2009 | 02:34 PM
Thomasv's Avatar
Power steering loud
This may not even be a problem at all but every morning when I start my car the power steering is extremely loud. I've checked the fluid levels and put them where they should be using only honda fluid.
The noise goes away after about 3 or 4 minutes and doesnt return really all day...I can faintly hear it from time to time while normal driving but its not really that loud than.
Is this normal or should I be ready for a failure soon?
Old Sep 27, 2009 | 08:24 PM
libert69's Avatar
18psi
i had the same noise and it got worse over time (2 weeks). had the ps pump replaced under the extended warranty.
Old Sep 27, 2009 | 08:35 PM
lilnate's Avatar
I had the same problem, there was a recall on it. i have an 04 TL, dealership should fix free of charge. the power steering rings may be worn.
Old Sep 28, 2009 | 10:47 AM
Majofo's Avatar
It's probably the o-ring on the inlet of the ps pump, it contracts in cold weater. When you start the car, open the cap on the PS reservoir.. if you see bubbles then it's definitely the o-ring.. remove the bolt on the inlet side, pull the o-ring and put in a new one. The new replacement o-rings are orange. It should take you 5 minutes.. replace it with the car off and some shop towels over the drivebelt to keep PS fluid from getting on it..
Old Sep 28, 2009 | 12:41 PM
Zigma's Avatar
As Majofo stated, its prob the O ring. I had this problem and they wanted to replace the power steering pump, i refused and had them just perform the recall and this fixed the issue. PS pump was fine...
Old Sep 28, 2009 | 04:15 PM
swoosh's Avatar
takin care of Business in
perfecto !!!!
i had the same problem in the past winter....i spoke to the dealer and they gave me an estimate to replace the ps pump.....i was outta warranty (so looking at $600) and i just came across this thread (some version of this thread) and saw the fix.....
went to the dealer....told them they forgot to put the o-ring back when the did the ps recall....they put it in there for free.....and damn no more noise.....
acurazine !!!
Old Sep 28, 2009 | 04:17 PM
Majofo's Avatar
Old Oct 5, 2009 | 09:02 AM
Thomasv's Avatar
Wow! Thanks guys! I knew something was frickin leaking under my hood...
I took a rag and whiped up below and whiped up the actual resevior itself....there was fluid leaking everywhere...I wasnt sure if it was a hose or what but we definitely saw bubbles in the fluid and that got me thinking too. I will definitely replace the ring! =]
Do i need to order this ring from the acura dealership or can i go to any local parts shop for it?
Old Oct 5, 2009 | 09:07 AM
Majofo's Avatar
^ You'd probably have to go to your local dealership. It's less than $1.
Here's the P/N:
91345-PAA-A01 (should be orange) #13 in diagram
Old Oct 5, 2009 | 09:14 AM
Thomasv's Avatar
ps inlet o ring ordered.....amount 97 cents....shipping 10 bucks...hahaha Acura dealerships make me laugh.
Old Oct 5, 2009 | 09:21 AM
Majofo's Avatar
^ why did you spend $10 unnecessarily? I hope you bought other parts as well.. not all dealerships are the same and there are several helpful members on this board who work at dealerships. I usually call around between Honda & Acura to find the best price on parts and use the online price to get the marked up price lowered.
Old Oct 5, 2009 | 10:56 AM
Thomasv's Avatar
becuase there is no local dealership where i live and id have to drive 2 hours to get there. I know 10 bucks sucks for shipping but I dont care. I just want to fix this stupid whiney noise asap! I didnt think about other members on the board being able to help me out but than again I cant even post a WTB yet in the black market for like another 9 days or so...so even than I dont have time to wait. I appreciate it though. I didnt have any other parts to order otherwise I would have.
Old Oct 5, 2009 | 11:02 AM
Majofo's Avatar
That sucks.. if you have a Honda dealership the parts are usually interchangeable although the P/N is usually different. btw.. Welcome to the board. Sucks to be a newbie but we were all there.. There's a lot of valuable info and knowledgeable members here.
Old Oct 5, 2009 | 11:47 AM
Phil 4:13
This was a very helpful post, I was about to buy and install a new pump this week. Going to get the o ring tonight...hope it works!
Old Oct 5, 2009 | 04:56 PM
Thomasv's Avatar
ok so i called my local honda dealership and it turns out they have the part in stock...called the okc dealership...cancelled the overpriced order lol and going to pick up my o-ring today ! Yippee! Thanks again for the help fellas! I was feeling bad all day for payin 10 bucks shipping
Old Oct 5, 2009 | 04:58 PM
Majofo's Avatar
another thread full of win!
Thomasv's Avatar
I am going to replace that O ring....should i think about replacing more than just that one ring?
Old Oct 5, 2009 | 05:00 PM
Majofo's Avatar
^ you could replace the PS fluid as well. I'll post up some pics of the job later that I did a while back or some caps from the service manual later this evening or tomorrow.. but the o-ring replacement alone should be golden.
Old Oct 5, 2009 | 05:02 PM
Thomasv's Avatar
sweet my dad is a manager of a local oil shop so we got the machinery to do so. If you want to post that info I would like to see it for peice of mind...gonna go buy about 5 bottles of honda fluid and have him run the machine to remove and replace. =]
Thanks, I never got my service manual I only get the links you guys post up here...id print it out but omg its long!
Old Oct 5, 2009 | 05:06 PM
Majofo's Avatar
yeah.. 2000 pgs.. it's cheaper to pay $60 for it on fleabay then buy ink to print it. It's a no brainer but I'll post up later for you and others.
Old Oct 8, 2009 | 09:05 AM
Thomasv's Avatar
ok so good news..i got the new ring and installed it yesterday...easy as hell for one...this morning i woke up and started the car and bam..the noise is GONE!
Moving on...
So i took off another peice to the power steering which I believe is the output (located right above the belt to the right) ...2 bolts and I found another ring that needs to be replaced. Its flat as hell and I bet this one only costs about a buck too...it seems to be leaking a little out of the top there but not alot. You got the part # for that one too? Or the official name?
Also...I originally ordered the ring (ps inlet ring) from Acura and it came in Orange like you said it should...i went to my local honda dealership and ordered the same ring and they gave me a black one with a diff part #. The inside dimensions of the rings were the same...but the black honda ring was slightly bigger than the orange when you put them up one on top of the other you could see the difference...needless to say I sent acura dealership in okc the black one honda gave me and kept the orange one...Hopefully they still give me a refund and dont notice my clever ways. Just curious if that black ring would work just the same or maybe even give me a "tighter seal"?
Old Oct 8, 2009 | 10:29 AM
unkicrackie's Avatar
4th Gear
this thread is lots of help, this should be the problem with the power steering noise when i first start my car.
Old Oct 8, 2009 | 10:32 AM
Majofo's Avatar
Moving on...
^ lol.. that's hilarious. Sorry, I was going to post up some pics after my last post but I was unexpectedly banned and then forgot about posting. Glad you got it resolved. You can reseal the whole P/S pump.. shouldn't cost you more than $15 in parts. I resealed portions of my PS pump on my MDX. Can you point out what part you're talking about below..
Old Oct 8, 2009 | 10:03 PM
olrac1's Avatar
OK so my 05 has noisy ps sound. I came upon this thread and figured i would walk out and see if there was any bubbles when I started the car and there was none! Should I start to get concerned that I may need a new pump or could it still be this o ring fix?
Old Oct 9, 2009 | 09:57 AM
swoosh's Avatar
dont just go and buy a new pump.....if you have the noise try the cheap options first (o-ring/seals)
Old Oct 9, 2009 | 01:06 PM
Thomasv's Avatar
I dont see what im talkin about in this diagram. Its really simple...the peice i removed to change the inlet o ring has one bolt...the one im talkin about now sits about 1 or 2 inches up higher and has 2 bolts you have to remove to take it out and see the seal...i think its the output o ring...but not sure.
Old Oct 9, 2009 | 01:09 PM
Majofo's Avatar
oh.. okay.. It definitely should hurt, hopefully that'll cure the leak.
Old Oct 9, 2009 | 01:22 PM
olrac1's Avatar
Ok so I stopped by the Acura dealership and they were good enough to pull the hose and determine that i did indeed have the old style O-Ring even though the Recall for the PS hose had allready be done .We shall see if this has taken care of the problem but at initial start up after o-ring was replaced I still here the PS pump we shall see!!!
Old Oct 9, 2009 | 03:56 PM
Thomasv's Avatar
Yea, your gonna hear it directly after you replace it..i did.. the next morning though my power steering issue cleared up... its been good ever since...
Old Oct 9, 2009 | 04:47 PM
KN_TL's Avatar
I had something making noise under the hood and I figured it was the power steering pump. I had my recall done recently and now that I read this thread, noticed that my pump is quieter too. It wasn't too loud to begin with but is totally quiet now.
Old Oct 10, 2009 | 01:29 PM
==Catfish=='s Avatar
Does anyone know the part # for the one from Honda?
Old Oct 20, 2009 | 09:09 AM
Thomasv's Avatar
Sorry catfish...i just had that number but ended up returning the oring i bought from honda to the acura dealership and ended up using the orange ring i recieved from acura instead......If i were you i wouldnt order the honda ring becuase it was different...Id honestly order the acura one which is orange. the inner dimensions of the ring were the same but the honda one was slightly larger than the orange one overall...it MIGHT make a tighter fit but still, id suggest the orange one.
Can we sticky this thread?
Old Oct 20, 2009 | 10:00 AM
Majofo's Avatar
^ They won't sticky because there are a 100 similar PS whine threads... and there'll be more after this one.. If you stay on the board long enough you see every issue come around at least twice. Next will be CV creaking sounds in the winter.. lol.
Old Nov 13, 2009 | 05:58 PM
Timbert's Avatar
My dealer here just replaced the o-ring on my 04 TL and they said it was "squished" when the original recall work was done at least two years ago. I brought in the TSB so they knew what I knew and explained the symptoms and it took them about 20 minutes.
Old Nov 27, 2009 | 09:53 AM
FL TL Driver's Avatar
Wink Power Steerring Buzz on cold days.
This forum ROCKS!!!.
You guys have already saved me a bundle.
I love my 2004 TL and as long as I can get the parts to keep it going I will.
The O-ring, $0.63 at the dealer and 15 minutes to change. Small Craftsman Ignition type 10 mm wrench after breaking torque with longer wrench, did the job.
Keep on rolling.
Old Dec 1, 2009 | 11:54 AM
fines's Avatar
7th Gear
So olrac1 was it the O-ring the problem?
Old Dec 2, 2009 | 12:03 PM
evnash's Avatar
EVNS TL
Wow this fixed my problem in 10 mins. thanks guys!
Old Dec 2, 2009 | 05:05 PM
olrac1's Avatar
Yep it took a day or so but its all set now
Old Dec 2, 2009 | 05:24 PM
4tLA-SPEC's Avatar
just replaced the o-ring and it fixed the problem
Old Dec 3, 2009 | 01:38 AM
Majofo's Avatar
created a DIY for reference:
https://acurazine.com/forums/showthread.php?p=11538857
