Exhaust leak
Old Nov 30, 2013 | 12:44 PM
Eaglesfan9106's Avatar
Exhaust leak
So I have a bad gasket between the third cat and the and the catback I went to advance.auto got a gasket. I have a xlr8 catback which is 2.5 inches. They couldn't find an exact fit but they found me a 2.7 inch gasket I just want to know will this work and will there be any drawbacks
Old Nov 30, 2013 | 12:45 PM
https://db.tt/k1cxPiPd
Old Nov 30, 2013 | 03:24 PM
45 ppl no help? Well anyways I went and replaced it anyway and wow I didn't realize how much it was effecting the performance and exhaust tone it was a bitch to replace. Here's the old one you could say it has seen better days. https://db.tt/Ot1glu96
Old Nov 30, 2013 | 03:33 PM
Nick216's Avatar
The Boss
Howd you know it was a leak or suspect somthing was wrong. Ever since i got ny jpipe it hisses when its cold but ive never thought .much
Old Nov 30, 2013 | 03:36 PM
Condensation was dripping from the area I said between the cat and catback so the obvious answer was the gasket
Old Nov 30, 2013 | 03:38 PM
Not the gasket connecting to the j pipe the other side
Old Nov 30, 2013 | 06:06 PM
LoveMyTL-S's Avatar
Nice to know, thanks for sharing.
Old Nov 30, 2013 | 06:07 PM
thisaznboi88's Avatar
I just use rtv copper gasket for the exhaust stuff
Old Dec 1, 2013 | 02:37 PM
3.2TLc's Avatar
Yeah, anytime you're messing with the exhaust flange gaskets and going aftermarket or modding....
a bit of sealant really helps when putting things back together.
Old Dec 1, 2013 | 07:50 PM
Well it already was a aftermarket gasket that xlr8 sent with their catback. And as.of today I drove a good distance levittown pa to Lincoln financial field aka the eagles stadium for the game. It's about 30 miles each way nd I checked it when I got there and when I got home and no leaks. It helps allot that is cold because you visually see leaks as vapor. But no leaks at all so I made the right choice using it
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
