Engines moves up and down
Old Jun 14, 2012 | 10:31 PM
akash4u's Avatar
With the car started (engine running), I had my wife shift from Park to Drive and then Drive to Park and I saw the front part of the Engine move up and down (like 1-2 inches). Is it supposed to do that under normal behavior?
2005 TL - AT Base 97K miles
Old Jun 15, 2012 | 04:44 AM
Turbonut's Avatar
No, better check the all the motor mounts, When one goes it puts strain on the remaining, so check them all.
Old Jun 15, 2012 | 07:07 AM
egonz36's Avatar
i would say its also the motor mounts. check with XLR8 he has great mounts with a few different setup option. i changed all 3 when my mounts with bad from XLR8 and no complaints
Old Jun 15, 2012 | 08:31 AM
akash4u's Avatar
Thanks egonz36 and Turbonut. My Acura service-tech told me that it does move to a certain degree and I have an appointment in for Monday to get that inspected. I will let you guys know how it goes. I still dont think it should move up and down "to a certain degree".
Old Jun 15, 2012 | 09:12 AM
ez12a's Avatar
the overexplainer
it will shift slightly but pretty sure not 1-2". front/rear mount might be shot.
Old Jun 15, 2012 | 02:43 PM
Paul07TypeS's Avatar
6th Gear
Sounds to me like one is completely torn. if the dealer says it is normal, ask to see another car that exhibits the same behaivor.
Old Jun 15, 2012 | 02:52 PM
Turbonut's Avatar
It certainly won't move 1"-2", but put it in drive, hold brake and blip throttle, a lot of movement mount(s) shot. If you look closely you may be able to see the area that has separated.
Old Jun 19, 2012 | 07:07 PM
newkatbie's Avatar
Check all motor mounts. Look for cracks and separation. You should be able to feel vibration at stops, if it is bad enough.
Old Jun 19, 2012 | 09:10 PM
akash4u's Avatar
Front mount is shot guys. After my visit yesterday, dealer saild they replaced it once before about 12K miles prior (85K milestone) and its gone again (97K miles now). For now they are blaming it on a defective part and got me covered under warranty. Vibration reduced now significantly.
Feb 25, 2020 09:57 AM
Joeyc850
Oct 30, 2015 12:15 AM
HOWELLiNC
Sep 18, 2015 11:12 PM
P1zzaman
Sep 17, 2015 04:56 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
