Possible Broken PCD Solution
Old May 1, 2012 | 11:12 AM
UA6's Avatar
UA6
So after cracking my 2nd rear pre cat delete I tried to experiment with some permanent fixes. The engine was jerking just enough to put stress on the welds so I removed the center and replaced it with a flex joint. This will provide relief for the welded sections. As the engine jerks the flex joint will allow it to move in either direction. Any thoughts or ideas or maybe something I am overlooking?
Old May 1, 2012 | 12:31 PM
gideon's_test's Avatar
Nice fixture...Let us know how it works out...
Old May 1, 2012 | 12:32 PM
in for longevity
Old May 2, 2012 | 05:34 PM
gwiffer's Avatar
Great idea!
What's the part number for that flex-pipe?
Will you be doing this to the front PCD also?
My only concern is that it won't last very long being so close to the head...+1 for test of longevity.
Old May 2, 2012 | 05:55 PM
UA6's Avatar
UA6
Just the rear for now. I haven't had any issues with the front. There really isn't a part number. Its just a flex joint with 2 1/2" piping. The flex joint itself is 4". I found this on Ebay for under $20.
Old May 2, 2012 | 07:42 PM
Turbonut's Avatar
Good idea, many use heavier mounts if they are available, but with the heavier mounts motor vibrations transmit into the passenger compartment and many cars have a flex pipe from the factory, e.g. Maxima/Infiniti.
Old May 4, 2012 | 06:43 PM
gwiffer's Avatar
I'm curious to know how the flexpipe will change the sound when used on the PCD. Give us an update once you install it.
What engine mounts are you using?
Old Jun 19, 2012 | 09:16 PM
rockstar143's Avatar
What a badazz innovator you are.
J.
Old Jun 19, 2012 | 09:24 PM
gwiffer's Avatar
I sent UA6 a PM a few days ago:
Originally Posted by UA6
Originally Posted by gwiffer
Did you ever install your re-welded PCD with the flex-pipe? I was curious to know how durable the flex-pipe will be when mounted so close to the head.
Brian
No issues so far. Shouldn't be a problem since that is what they're made for.
Old Jun 19, 2012 | 09:34 PM
He doesn't post much, but I dig that he's an innovator and thinks outside the box to find solutions.
SiClone
Oct 1, 2015 10:22 PM
KBTypeS
25
Oct 1, 2015 04:49 PM
juanrl
Sep 29, 2015 03:25 AM
LoneRonin
Sep 28, 2015 09:11 AM
AcuraKidd
Sep 25, 2015 11:18 PM
