Engine light blinks
Old Dec 18, 2017 | 04:27 PM
HENRYMONCIVIS's Avatar
3rd Gear
Engine light blinks
I have a 2005 Acura TL I’m having a problem with it the engine light is blinking , I’ve checked Injectors , timing belt , coils , spark plugs ,compression is good also and there all good
many ideas what it can be ?
Old Dec 18, 2017 | 04:29 PM
how did you check your coils/spark plugs?
engine light blinking = misfire
Old Dec 18, 2017 | 04:31 PM
losiglow's Avatar
Does it stay on after it blinks or does it go off? If it goes off, it usually indicates that the ECU was recently reset. If it stays on then that's obviously a problem. You might consider taking it to an auto parts store and having them scan it for codes. Or getting a OBD-2 Bluetooth module with the Torque app on your phone which will tell you all the information as well.
Old Dec 18, 2017 | 07:48 PM
nfnsquared's Avatar
A flashing MIL indicates misfires happening at a rate that could cause damage to the CATs.
Is this a 6MT?
If it flashed 5 times and then stays on right after startup, then the readiness codes aren't set.
What mods/changes have you made recently, if any?
Old Dec 19, 2017 | 06:43 AM
subscribed.
Old Dec 19, 2017 | 12:38 PM
3rd Gear
a flashing mil indicates misfires happening at a rate that could cause damage to the cats.
Is this a 6mt?
yes its a 6 speed transmission 2005 acura tl , what do you mean when you say readiness codes arent set, what it does i start the car engine light just blinks and will stay on and it will blink hear n there , i have put my reader on it and its readin misfires and eveything checks out fine what i explained in my thread , now can it be possible my cat , is messed up ??
Old Dec 19, 2017 | 12:39 PM
3rd Gear
and no there arent any mods to the car its all stock
Old Dec 19, 2017 | 12:50 PM
you will have to test!
test fuel pump.
test catalytic converters.
test the heads by having a compression and leak down test...
basically, you or a mechanic needs to test these components to find the bad one
Old Dec 22, 2017 | 12:58 PM
brianhed's Avatar
I had misfires issues also. Don't drive too long with them. I waited too long and ended up with a bad pre-cat and a partially clogged main cat.
New sparkplugs and coil packs fixed my problems.
playboyace35
1G TSX Problems & Fixes
Feb 9, 2019 07:54 PM
acura4eva
May 13, 2009 09:21 PM
100degrees
May 1, 2007 01:49 PM
AcuraTLInjen
Nov 22, 2004 10:46 PM
