Engine degreaser white stains
Old 07-17-2016, 06:24 AM
E39
E39's Avatar
Used some engine degreaser which after it dried left white stains on mostly metal parts like the alternator for example and some rubber parts. Tried soapy water and rinsing but after it dries the stains are back. I'm not sure if I've permanently stained the metal. Are there any negative effects to this aside from cosmetics? Any way to reverse this?
Old 07-18-2016, 11:31 AM
WDPanda's Avatar
So did you wash your engine?
Old 07-18-2016, 11:39 AM
shmobby's Avatar
Did you leave the degreaser on the engine or wash it off with water while it was still wet?
Old 07-18-2016, 12:09 PM
tk2k6's Avatar
You're not supposed to wash your alternator with anything. I always covered it with a plastic bag when I detailed the engine. Harsh chemicals could exfoliate the wire coils inside. You could blow some compressed air thru it if you really think it needs a cleaning that bad. Try to dress up the rubber parts with something that'll take off the white residue and wipe them clean.
Old 07-18-2016, 12:17 PM
WDPanda's Avatar
All you guys who washed the engine should consider changing your ground wires. I imagine a wash would have started the corrosion process. I like my engine dirty.
Old 07-18-2016, 05:22 PM
E39
E39's Avatar
Left it on for a bit then used compressed air to blow it off. When I saw the white stains I used a garden hose and some diluted dish washing soap to wash away what I think is residue from the degreaser but the white stuff keeps coming back. I'm not sure if the degreaser caused aluminum parts to oxidize because the weird part is the white stuff isn't only on metal parts but also on rubber parts etc.
Old 07-18-2016, 05:23 PM
E39
E39's Avatar
I made sure to be careful of the alternator and electrical components.
Old 07-18-2016, 05:26 PM
E39
E39's Avatar
It's funny because my ground wires were the original reason I even decided to wash the engine bay as the ground wires looked like they had some blue coolant caked on them or something so I figured I'll just give the engine a quick hit of degreaser. Now everything looks like shit lol.
Old 07-18-2016, 05:50 PM
shmobby's Avatar
That was corrosion.
gavriil
03-01-2024 07:56 AM
gavriil
11-27-2023 11:35 PM
gavriil
09-26-2023 05:19 AM
Black Tire
12-18-2017 08:15 AM
GK83
09-13-2014 12:48 AM
Quick Reply: Engine degreaser white stains
