'05 TL no power fuel pump/injectors
Hi all,
Here is the story. Had what seemed like a failing starter..it would slow crank/drag and eventually start. Took car to a guy who said it was a bad connection to the starter.. His English isn't the best btw. he said battery went dead so he put a dif battery in and tried to start the car but it would not start because immobilizer "green Light" was flashing. I called acura got the emergency Brake immobilizer bypass code did the procedure still no start. eventually i realized the Check engine light was not coming on with the key on. tried plugging in a scan tool and had no communication. (all fuses and relays Have been Tested). Was able to jump the main fuse and got the immobilizer light out and check engine lights up as well as scan tool now connects but still no start. Seems fuel injectors aren't being powered. Does this seem like a faulty ground somewhere or what? I've searched all over for answer with no luck as to how to troubleshoot from this point on. Is it possible when he was repairing what ever wire was faulty to the starter, I believe he said it was a ground that something could have been knocked loose disconnected etc? Any advise on what to do next would be appreciated thanks!!
