Engine control module to be replaced
2006 TL here
Engine cranks but would not start (TPMS message flashes on dashboard), towed to Acura dealer and states:
engine control module to be replaced because of water intrusion from A/C evaporator case.
Due to unclog case drain tube...WTF?
Is this legit??
Thanks for any input
Is this legit??
Registered but harmless
Received 1,106 Likes
Now, the interesting question: what was clogging the drain tube?
If you search for terms regarding water and fried ECM/ECU, several threads here on AZ mention that mechanics or oil change shop employees will sometimes put a bolt in the end of the A/C drain tube to stop condensation from dripping on them while changing oil or working on the car. Then they forget to remove the bolt to unplug the A/C drain, resulting in condensation backing up and dripping onto the ECM... A couple of Acura techs ran into several cases of this.
FYI, a fried ECM can cause misfires and fried ignition coil packs, so don't be surprised if the car needs new coil packs.
G/L; hope you get things fixed.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
HeloDown
09-08-2015 06:51 PM
