Engine control module to be replaced
Old Oct 17, 2012 | 08:34 PM
steve5chang's Avatar
4th Gear
2006 TL here
Engine cranks but would not start (TPMS message flashes on dashboard), towed to Acura dealer and states:
engine control module to be replaced because of water intrusion from A/C evaporator case.
Due to unclog case drain tube...WTF?
Is this legit??
Thanks for any input
Old Oct 17, 2012 | 09:16 PM
AndrewA's Avatar
wow, these are popping up like crazy. do a search on here and you'll see a few others recently.
Old Oct 17, 2012 | 09:18 PM
Will Y.'s Avatar
Registered but harmless
Originally Posted by steve5chang
...engine control module to be replaced because of water intrusion from A/C evaporator case.
Is this legit??
Afraid so-- this does happen, because overflow of a plugged A/C drain tube will cause water to drip on the ECM/ECU/PCM, which is located on the floor of the console tunnel behind the audio stack.
Now, the interesting question: what was clogging the drain tube?
If you search for terms regarding water and fried ECM/ECU, several threads here on AZ mention that mechanics or oil change shop employees will sometimes put a bolt in the end of the A/C drain tube to stop condensation from dripping on them while changing oil or working on the car. Then they forget to remove the bolt to unplug the A/C drain, resulting in condensation backing up and dripping onto the ECM... A couple of Acura techs ran into several cases of this.
FYI, a fried ECM can cause misfires and fried ignition coil packs, so don't be surprised if the car needs new coil packs.
G/L; hope you get things fixed.
Old Oct 18, 2012 | 01:52 PM
Manimal_Forever's Avatar
Yeah i was a victim of that. still in the process of getting it fixed
-_-
Old Oct 18, 2012 | 03:08 PM
gwiffer's Avatar
Anyone have an idea for some kind of water jacket for the ecu?
Old Oct 18, 2012 | 11:38 PM
libert69's Avatar
18psi
^just spray some compressed air in the a/c drain tube under the car every couple of months
Old Oct 19, 2012 | 09:10 AM
AndrewA's Avatar
The AC drain tube is on the passenger side right? Any pics?
Old Oct 19, 2012 | 12:59 PM
libert69's Avatar
18psi
^yes it is, no pics here. just turn on the a/c and after a few minutes youll see the drip below the car....theres your tube
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
HeloDown
Sep 8, 2015 06:51 PM
