Door pins again!!!!!!!
Old Jul 8, 2011 | 06:36 AM
**WhItE-aNgEl**'s Avatar
Hey guys my door pins are bad again! Why does this happen. It was raining really hard yesterday I woke up this morning and my dash shows my both passenger side doors open. What can I do to fix this? I'm under warranty. Should I take it to the dealer?
Old Jul 8, 2011 | 07:13 AM
paperboy42190's Avatar
yes, u should. why would you bother to fix something that can be done for free?
Old Jul 8, 2011 | 07:24 AM
^cuz sometimes the dealership messes things up even more.
I have a warranty, but my car will never see the dealer.
Old Jul 8, 2011 | 07:36 AM
Exactly! I hate taking my car to the dealer. Is there any fix to this maybe adjusting it? I know there's one wire that goes to them if I unplug it and plug it back in will that mess up anything else? And what might of caused this ?
Old Jul 8, 2011 | 07:38 AM
I remember that you had a leaking problem.
did you fix the leak?
Old Jul 8, 2011 | 08:29 AM
The leak was in my fuse box. I took everything apart and there's no signs of water in there. My door pins always seem to go bad after I have an alarm system hooked up to. I have the st800 alarm system. And I had to hook up a a wire to every door pin wire. Idk if that's the problem tho. All the times that it has happened it's been raining. Yesterday it was only the back passenger door. I went to my car this morning and the passenger door was bad as well.
Old Jul 8, 2011 | 08:30 AM
Go back over your install.
something is amiss.
Old Jul 8, 2011 | 08:34 AM
something is amiss.
I guess I'll start with that. And go on from there.
Old Jul 8, 2011 | 08:36 AM
if it only started happening after your install, then thats your problem.
Old Jul 8, 2011 | 08:52 AM
My install was about a month ago. Why would it happen now? I dont think any wires came lose cuz everything was soldered. And why would it happen the first time it rained hard in nj since the install? I know a lot of ppl who have door pins problems and there factory alarm goes off. And they dobt have any aftermarket alarm. I heard water gets in thru the windows sills and shorts them out.
Old Jul 8, 2011 | 09:26 AM
Jesstzn's Avatar
Originally Posted by **WhItE-aNgEl**
I know a lot of ppl who have door pins problems and there factory alarm goes off. And they dobt have any aftermarket alarm. .
This is the first time I have ever heard of this.
Old Jul 8, 2011 | 10:13 AM
Here's another case. And there's a lot more I'm not the only one. Does anyone know why this happens plz help.
https://acurazine.com/forums/showthr...ight=Door+pins
Old Jul 8, 2011 | 10:15 AM
^the battery was going bad.....
your problem happened after the install.
which would lead me to believe the install is causing your door pins to go bad
Old Jul 8, 2011 | 10:19 AM
Jesstzn's Avatar
X2 .. that thread wasn't conclusive.
Old Jul 8, 2011 | 10:38 AM
My door pins went bad before the installation once. And the Acura dealer fixed it. And it was also raining that day.
ton8383's Avatar
seeing that it happens when it rains seems like something in your install is shorting out
Old Jul 8, 2011 | 10:43 AM
Obviously. Question is how?
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
