Door Locking Beep Problem
Old May 20, 2009 | 08:43 PM
4play's Avatar
Question Door Locking Beep Problem
i have a problem with my alarm... when i lock the car it never beeps and the lights do not flash.. i already checked the settings, and beep is turned on.. i cant find any bad fuses. all doors, trunk, and hood are closed according to the multi viewer.. can anyone help?
Old May 20, 2009 | 09:58 PM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
bad hood switch??
Old May 20, 2009 | 11:15 PM
Crazyace718's Avatar
I'm pissed that the doors dont auto lock.
The beep is cool though.
Old May 20, 2009 | 11:26 PM
o4Komodo's Avatar
Rev High; Drive Happy
Mine auto locks sometimes....
There's a setting for it in the display thinger
Old May 21, 2009 | 10:07 AM
pbcmedia's Avatar
HOME SWEET HOME....
it auto locks if u lock the doors, unlock the doors but never open the door... then it'll relock after a predetermined time set on ur mid
Old May 21, 2009 | 10:49 AM
blkaspec's Avatar
Full of water...
the alarm activates whenever the driver door locks. you can manually press the lock down and then shut the door, you can press the fob once, and you can press it twice. all these will activate the alarm. i think the beep is just a confirmation, and like others have said, it lets you know if you forgot to close something like your trunk. beep > horn honk
Old May 22, 2009 | 07:27 PM
4play's Avatar
ive actually checked everything.. all doors hood and trunk are closed. i made sure by checking the multi-viewer in the dash... the car doesnt beep and the alarm light doesnt blink... any ideas?
Old May 22, 2009 | 11:46 PM
jeowen's Avatar
Originally Posted by subinf
to tell you to stop pressing the lock button
ahhah- daaaaang old thread
Old May 23, 2009 | 12:12 AM
chairguru22's Avatar
Unregistered User
One press is a stealth lock without a noticeable to everyone honk or beep. Two presses give you a beep so you and everyone nearby knows you locked your doors.
Old May 23, 2009 | 03:21 AM
csmeance's Avatar
I created a new thread and moved the relevant posts here to make it easier
Old May 25, 2009 | 07:54 PM
sukiyaki's Avatar
I am having this issue too. Also when I am in traffic, the car autolocks when it hits 10mph. Please help me! Any ideas would be appreciated.
Old May 27, 2009 | 07:35 PM
4play's Avatar
you can turn autolock at 10mph off through the dash..
im still trying to figure out why my car doesnt blink or beep when i lock/unlock.. can anyone help?
Old May 27, 2009 | 07:58 PM
import4life's Avatar
my car stopped beeping after i installed led turn signals for the front turn signal and rear turn signal, but i dont mind the beep as long as the doors still lock. hope this helps
Old May 28, 2009 | 10:29 AM
sukiyaki's Avatar
I am aware that I can turn off the autolock from the dash, but the autolock didn't used to lock again even when the car is already locked. I'm just trying to figure out what happen. I think one of my door actuators may be going bad. When I lock my doors with the remote while sitting in the car, I can hear a noise coming from my rear passenger seat. Could that be the issue?
Old Jul 20, 2009 | 12:02 PM
gatoferoz25's Avatar
Hey how do you do the hack navi and what is that for....Maybe GPS update or what is that means...thanks....
Old Jul 20, 2009 | 02:54 PM
pohljm's Avatar
^^ depending on the year of the car, it removes the nag screen and allows you to use your own welcome screen image
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
Azonics
Sep 22, 2015 05:28 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
