Door Handle HELP
Old Oct 2, 2007 | 09:23 AM
JRFlex's Avatar
Door Handle HELP
Ok so the small piece on the driver side rear door fell off ...went to the dealer and bought the part ( $12 ) assumin it was an easy install....figured out it wasnt...from the looks of the instructions on the internet/forum i have to practically take the door apart theres gotta be and easier route...if i take it to the dealer im gonna get jacked for the labor since my warranty is out...if theres not an easier route i may have to take the dealer hit on labor...should i cover the exposed metal piece in the meantime????
Thanks..
Old Oct 2, 2007 | 09:49 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
you have to remove the child lock cap... and unscrew a bolt that's visible behind it... then just snap the new cover on... then put the bolt back on and then put the child lock cap back on the door panel...
Old Oct 2, 2007 | 11:06 AM
Bearcat94's Avatar
AZ Community Team
Thanks..
Sorry - Are you talking about the Inside Door Handle or the Outside Door Handle?
If it's the outside, there is a TSB on that. Some Covers don't fit right and fall or get knocked off. The Dealer should replace that under warranty. The TSB recommends that both the Cover and Bracket be replaced together to insure a proper fit.
Here is the TSB link: http://www.in.honda.com/Rjanisis/pubs/SB/B07-043.PDF
Old Oct 2, 2007 | 11:44 AM
JRFlex's Avatar
Bearcat94: Its the outside handle...im just tryin to avoid payin labor since my warranty is expired...
Old Oct 2, 2007 | 12:02 PM
Bearcat94's Avatar
AZ Community Team
Call 'em. I think they might Good Will it. It's only a 20 minute job (for them. For me, it's 20 mins to open the package right; Remove the door panel? There's not enough daylight).
Let them know that you know there is a TSB, that you've already purchased the part and are just asking for Good Will on the Labor.
Can't hurt. Call a couple of dealers or your salesman. Eventually somebody will say "yes".
Evader's Avatar
Let's Go Pens
Do you have a picture of what your dealing with? This is an easy DIY but your making it seem a little more complicated.. If we saw a picture we could give you a more detailed explanation on what to do. If it's the cap i'm thinking of (the little one, similar to the one where the key hole is on the driver door) this is very simple, you just remove the little meta piece inside with a flathead and then put the cover back on. I did this when I covered up my keyhole on my driver door, i'm sure it's bascially the same
Old Oct 2, 2007 | 04:17 PM
Pocus's Avatar
Team Anthracite Member
Why isn't that TSB part of this?: http://www.in.honda.com/Rjanisis/pubs/SN/B070800.PDF
Just asking because I totally missed this TSB!
Old Oct 2, 2007 | 04:32 PM
Bearcat94's Avatar
AZ Community Team
I don't think that's the right link - that's a Service News link. I posted the TSB link earlier.
I don't totally get it either Evader. I know the TSB says to replace the BASE and the CAP. I did the shaved door handle - it was super easy, but it was only the CAP. Not sure what else needs to be done to replace the BASE as well.
My guess is that ACURA thinks that if the BASE/CAP didn't fit quite right before, the best bet to insure proper fit is to replace both.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
