DIY A-105: Power Steering Whine fix
Old Feb 22, 2012 | 10:31 AM
  #441
Majofo's Avatar
Nothing to worry about.. just your HP PS hose leaking and the coolant burning on the rear bank. I'm guessing the smell is a bit sweet. Luckily it sounds like no major damage occurred. Make sure the ticket does state that the hose did indeed leak / pop and cause coolant to burn. You might get them to replace anything that might be damaged. Check firewall, rear motor mount and o2 sensors for any residue / damage.
Old Feb 22, 2012 | 10:38 AM
  #442
rockstar143's Avatar
...or maybe even make sure he has the ac vent set to recirculate!
Old Feb 22, 2012 | 10:39 AM
  #443
timsta's Avatar
awesome. thanks majofo.. hopefully everything goes smoothly. have not drove my car for about a week now and miss it lol
Old Apr 8, 2012 | 11:33 AM
  #444
JTbulldawg's Avatar
Thanks!
I had my new (to me) Type S for about a week when it started making that whine in the mornings... just did this fix and she is nice and quiet again. Will be doing the fluid flush this coming weekend... i didn't have enough fluid to do it yesterday. Thanks for the DIY!
Old Apr 16, 2012 | 06:55 PM
  #445
vectorracer's Avatar
thank you very much, just did it 10min job and whine is gone, just as precaution to people changing there ps fluid i needed two bottles of honda oem stuff not one like i was told at the dealer. however no noise what so ever i think there still bubbles in the power steering resvoir any tips? thank you guys again for any info.
Old Apr 16, 2012 | 07:21 PM
  #446
Will Y.'s Avatar
Registered but harmless
Originally Posted by vectorracer
...i think there still bubbles in the power steering resvoir any tips?
Don't worry about it, as the bubbles should clear out after a day or so of use.
If bubbles still appear in the system after a couple of days, that likely means a leak somewhere else in the power steering system.
Old Apr 16, 2012 | 10:13 PM
  #447
Majofo's Avatar
The techs only grab one bottle when doing PSF changes. The parts counter doesn't know any better and neither does the customer in the waiting room.
Trust me, most techs grab one bottle. Doesn't mean it's a one bottle job, they usually just suck out a bottles worth. Also something to consider.. the res supposedly has a filter catch on the outlet side that gunks with crap. It was recommended to me to replace the whole res.
Old May 20, 2012 | 07:21 PM
  #448
BDoggPrelude's Avatar
Just did this fix today in less than 5 minutes. Paid $0.67 for the new o-ring and about $5 for some power steering fluid. Thanks for the write-up Majofo.
For anybody that is having this problem...for the love of god do not pay the stealership to fix it. My wife could have done this and she has absolutely no mechanical skills whatsoever. It is literally the easiest thing I've ever done on a car.
Old May 20, 2012 | 10:33 PM
  #449
Not2shabby's Avatar
While doing the 105k maintenance at the stealership, I had them replace the 0 ring and put new power steering fluid in the car because ive had that annoying noise for a while now. They said this would get rid of that noise. 2 days later....the noise is still their? any suggestions?
Old May 21, 2012 | 08:18 AM
  #450
I had a slight leak from my ps pump...and almost all my o-rings were brittle etc. Made a thread about a total overhaul on it...
Old Sep 11, 2012 | 01:47 PM
  #451
imj0257's Avatar
Q('.')=O
So as some of you know I got my 105k service done. Let's just say they forgot to do something correctly so I had to take it back and they replaced my power steering pump.
Ever since then I have the noise you are all talking about. I can't hear it when I'm driving but can definitely hear it when I start the car cold (not cold outside aka 80 degrees) but cold as in not running for a long time; and of course when I move the wheel side to side. And I do see some little bubbles in the power steering reservoir.
My guess is that when they replaced my pump they used the old black ring. I will go to my dealership and pick up the new O-ring and try this. Based on what everyone posted in here I'm positive this should fix the noise. Oh and the dealer is charging $2.50 for the ring! Blasphemy!
Old Sep 11, 2012 | 06:19 PM
  #452
imj0257's Avatar
Q('.')=O
Btw does this ONLY happen in cold weather? Or warm weather too? And does the sound ALWAYS go away after driving for a while?
Old Sep 12, 2012 | 11:19 PM
  #453
Fatfrii's Avatar
how the hell did u guys get that 10mm bolt off mine is on so freakin tight that its stripping! turns out the hose for the same part had a hole. changed that and now its fine. but i still want to change the O-ring for the heck of it...any tips to get it off? only thing that will fit is a regular wrench
Old Sep 13, 2012 | 02:27 AM
  #454
Will Y.'s Avatar
That doesn't sound right.
The bolt is not torqued that tightly-- I used the box end of a 10 mm. standard combo wrench and the bolt came off with no issues at all.
Sure you're turning the bolt the right way?
Old Oct 12, 2012 | 10:11 AM
  #455
THEReeM718's Avatar
Type Sour
Just changed the O ring and power steering fluid. Noise is gone! Thanks to this thread
Old Nov 5, 2012 | 12:08 PM
  #456
Trunk Monkey's Avatar
Coolest A-zine Member
Bump for new comers, people with this problem....and because my fluid looks like this! haha
Yeah. My PS whine is LOUD in the mornings now. Going to pick up an O-ring at the dealership at lunch and see if it fixes it. Lets hope!
Also, does this PS fluid look like it needs to be replaced or does it look okay for now??
Old Nov 14, 2012 | 12:17 PM
  #457
Pennstater's Avatar
I too had the PS whine on cold mornings when the engine was cold (I have an '05 with just over 54K miles). My PS fluid looked just like what Trunk Monkey posted above. I wound up sucking as much of the PS fluid out of the res using a turkey baster. Got it all out of the res, started the car, turned the steering wheel lock-to-lock a couple of times (up on jack stands), shut it off and sucked out more PS fluid. I then changed the o-ring (used a 10mm combo wrench, box end; came off easy) and reassembled. I filled the res up with one bottle of OEM fluid (12oz), started the car, turned the steering wheel lock-to-lock a couple of times (with the res cap off) and then shut it off. A majority of the PS fluid was now gone in the res, so I filled it up with my second bottle. Repeated the start car, turn steering wheel, shut off car step again. The PS fluid in the res dropped, but not completely. Filled to the upper level and repeated the process. I still had some new PS fluid left, and seeing that the fluid still looked dark brown (the new stuff is almost clear), I sucked out some more fluid with the turkey baster, filled it up to the top level and redid the start car, turn steering wheel, shut off car step again. The fluid level remained at the same level this time, and most of the bubbles had disappeared. Still looks a little too brown for me, so I will probably go back and get a few more bottles of OEM PS fluid and suck out some more. Kind of like the ATF 3x3 process. You'll definitely want at least two bottles of PS fluid going into this procedure.
It is a pretty quick and simple job, and it eliminated the whining noise I was having (although we haven't had any "cold" weather since the last bout a couple of weeks ago). Should have some cooler weather this weekend, so time will tell if the noise has been eliminated for good.
This is a great thread; hell, Acurazine is the greatest web site ever!!!
Old Nov 14, 2012 | 12:40 PM
  #458
^^^agree with those last sentiments.
Glad you had success...great advice for everyone!
Old Nov 14, 2012 | 10:47 PM
  #459
THEReeM718's Avatar
Type Sour
Cold morning today and noise is back. Goes away after a few minutes driving. Should I change the power steering fluid again? Anyone? Thanks
Old Nov 15, 2012 | 09:57 AM
  #460
swoosh's Avatar
takin care of Business in
^^^ sorry didnt read the prev post but did you change the Oring? also do you see bubbles in the reservoir ?
Old Nov 15, 2012 | 10:25 AM
  #461
THEReeM718's Avatar
Type Sour
Yes replaced o ring and PS fluid and yeah I saw bubbles this morning. Guessing I have a leak how much for parts and labor replacing PS pump gaskets etc?
Old Nov 15, 2012 | 10:43 AM
  #462
swoosh's Avatar
^^^ I think there might be any other place where air might be seeping into the PS system....
I think a PS rebuild is in order
Old Nov 15, 2012 | 05:32 PM
  #463
fly_mdx's Avatar
Have the same problem - called the dealer today to ask about replacing the o-ring and was told "Forget it - that won't fix it. You need a new power steering pump. When can you come in?". Bought the o-ring for $2 and took it to a mechanic down the street from the dealer who installed it for $30 bucks. (I'm not too handy!). Let's hope the problem is solved!
Old Nov 16, 2012 | 02:06 AM
  #464
flwrngls's Avatar
2006 Acura RL @65k miles!
O ring didn't fix my problem
I've had the O ring replaced and the noise on cold mornings is still there.
Hate to spring for the pump!
Old Nov 16, 2012 | 06:39 AM
  #465
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-pump-overhaul-pics-sm-scans-841134/
Old Nov 16, 2012 | 07:50 AM
  #466
fly_mdx's Avatar
Looks like the o-ring was the problem! Went out this chilly morning and no noise!! Hopefully it stays that way!
Old Nov 21, 2012 | 09:05 PM
  #467
Slooo97CL's Avatar
I can't believe this just happened to me the night before thanksgiving! I turn the car on and notice a whine and turn the steering wheel slighty and have a huge whine/pulsing vibration. Take it for a spin because I feel like it will go away, NOPE. Pull into the garage open the hood, take the cover off, pop the top of the power steering reservoir and bam, bone dry. So now I am going to be on a mission for power steering fluid, and an O ring before I have to be at work at 7am Friday morning. I guess it could be worse...wish me luck
Old Nov 27, 2012 | 04:05 PM
  #468
marcinposluszny's Avatar
3rd Gear
hey ihave this noise and also the steering becomes hard sometimes, will this fix it?
Old Dec 1, 2012 | 08:13 PM
  #469
3rd Gear
i just did this fix today and it work perfect but i changed both o-rings just in case
Old Dec 17, 2012 | 01:32 PM
  #470
AP2-2-TL's Avatar
I somehow dropped the bolt. Has anyone had this problem?
Where did you find it???
I think it fell on the towards to the driver side of the car and on top of the engine. I did not hear it plastic or see it on the ground. I used a flash light and could not find it.
Old Dec 17, 2012 | 01:36 PM
  #471
Majofo's Avatar
It might have fallen between the rear bank head.. there is a gap there that likes to catch things like that.. between intake manifold and head.
Otherwise.. around rear mount or plastic shroud covering trans.
Old Dec 17, 2012 | 01:42 PM
  #472
AP2-2-TL's Avatar
Majofo - I hope you are right... Would it be worth picking up those magnetic antenna tools? Do you know if the bolt is magnetic?
Old Dec 17, 2012 | 01:44 PM
  #473
Majofo's Avatar
nah.. skinny fingers and a mirror
Old Dec 17, 2012 | 01:47 PM
  #474
nfnsquared's Avatar
If you can't find it, then I'd say yes. Saved my ass many a time
p.s. obviously don't drive that car to buy the tool...
Old Dec 17, 2012 | 01:48 PM
  #475
AP2-2-TL's Avatar
shit. I dont have skinny fingers. My gf does lol hopefully she will take one for the team.
Im confused, is the bolt magnetic?
I had a friend drop me off at work and he will be picking up the magnetic arm from harbor freight. So hopefully we can find it this evening when i get off.
This sucks
Old Dec 17, 2012 | 01:52 PM
  #476
nfnsquared's Avatar
I don't no if it is or not... sorry. But at any rate, a mag grabber is less than $5 and that along with a mirror is a highly recommended addition to your tool set
Old Dec 17, 2012 | 01:59 PM
  #477
Majofo's Avatar
My wife has saved me several times..
the magnetic arm won't fit back there.. but I have used the telescoping arm to pick up bolts to prevent cat scratches, so I'm with nfn.. if you don't have it, you should. Also grab a magnetic catch can from harbor frieght. Basically a huge magnet under a tin to hold all your bolts.
Old Dec 17, 2012 | 02:20 PM
  #478
AP2-2-TL's Avatar
So you guys are saying those Telescoping Magnetic Arms wont fit but my hand will?
If so, that doesn't make sense to me. Those arms are no thicker than a pencil
Old Dec 17, 2012 | 03:00 PM
  #479
Majofo's Avatar
It's tight.. and the magnetic arm won't bend.
Find a flex magnetic arm.
Old Dec 17, 2012 | 03:08 PM
  #480
swoosh's Avatar
^^^ I dropped my switchbacks in the headlight assembly and had to bend the magnetic arm a little bit to remove the switchback....once the switchback was out, i went ahead and "straightened out" the magnetic arm
