CV axle question
Old Mar 22, 2016 | 05:44 PM
cinobyte's Avatar
CV axle question
I just had the axles replaced about a month ago and the passenger side started dumping grease 2 days ago. its pushing it out right around the lower ball joint. I don't see any tears in the boot and the clamp seems tight. any suggestions on why before i take it back to the mechanic.
sadly i purchased the parts (oem) from Acura Of Peoria and had the shop put it on so I am sure they will blame me some how.
any info would be great thanks
Old Mar 22, 2016 | 05:52 PM
Pics?
Old Mar 22, 2016 | 08:20 PM
cinobyte's Avatar
i didn't take any pics there wasn't much to see except axle grease was everywhere. I can take the wheel back off and gets some pics tomorrow. I want to look at the other side anyway
Old Mar 22, 2016 | 09:10 PM
csmeance's Avatar
Is the axle aftermarket? If yes, there have been reports that the aftermarket seal on the axle is a tad to small and to use an OEM one.
Old Mar 22, 2016 | 11:59 PM
cinobyte's Avatar
It was oem part straight from Acura Of Peoria. I pulled it out of the box.
Old Mar 23, 2016 | 05:52 AM
Turbonut's Avatar
If grease is leaking, only a rip in the boot, or clamp is loose/moved during installation will cause the problem. Wipe down and clean with brake clean, then turn the axle to get a 360 degree view of the area.
Old Mar 30, 2016 | 04:29 PM
cinobyte's Avatar
just wanted to update and get an opinion. The shop cleaned it all off no rip in the boot and the clamp was pretty tight. they tightened the clamp one click. any way they said they have seen brand new oem boots push out grease if over filled or some other reason they gave. but they said it looked fine and I shouldn't worry about it. so do you agree that i should just let it go...
Old Mar 30, 2016 | 10:07 PM
musiclevelz5's Avatar
I have had the same issues with new axles. They had air trapped in the boot and forced some grease out within a few months of driving. After that the axles stopped doing that and they performed flawless for several years.
You should be okay with them.
Old Mar 31, 2016 | 06:08 AM
Turbonut's Avatar
Grease shouldn't come out of the boot seal(s) and sorry to say, that air is certainly inside the boot as it isn't vacuum sealed.
If they managed to tighten the clamp slightly, that should prevent any future leaks, but keep an eye on it.
Old Mar 31, 2016 | 08:24 AM
flyromeo3's Avatar
If they managed to tighten it a bit more. Then to me it was loose to begin with.
Ziplok
Apr 3, 2016 06:59 PM
Kaiii
Feb 1, 2016 03:50 PM
bsprinker
Jan 31, 2016 02:16 PM
HarryMTorres
Jan 28, 2016 10:21 PM
Powder Monkey
Jan 14, 2016 11:18 AM
