Ignition problems
Old Mar 31, 2016 | 08:27 AM
Touchdown88's Avatar
4th Gear
Ignition problems
I have an 06 TL and from time to time when I get in to start the car. The car would start off dead, then turns on but after it turns on the startup would be a little rough. The Rpms would be at the regular idle rpm range then it would drop like the car is about to turn off then it would go back up again.sometimes if turn the wheel while in park the Rpms would dip then come back up. Even when I drive it, I would hit a red light the Rpms would drop low then come back up. Are my spark plugs going bad? Alternator failing? Bad battery?
Old Mar 31, 2016 | 08:45 AM
alexb92's Avatar
Have your battery tested at a local automotive store. Replace it if its bad. If its okay, do the idle relearn process: Let the car cool down and then remove the battery for 15 minutes, then connect it and start the car. Leave all accessories off, and let the car idle until the radiator fan cycles on and off at least twice.
gavriil
Feb 11, 2022 11:21 AM
kingofbytes
Jun 14, 2018 07:52 AM
jchiodi
Feb 1, 2018 08:22 PM
510waffles
Mar 16, 2016 11:32 AM
Ryley
Feb 27, 2016 03:47 PM
