Coolant issue
Old Aug 28, 2019 | 12:42 PM
2Quik's Avatar
Coolant issue
I walked by my daughters car and smelled coolant so i popped the hood and notice that the coolant splashed on to the engine.
The only noticeable place i notice it's coming from is the coolant reservoir or reservoir cap. Anyone have an idea on what the issue is, do i just need a new reservoir and cap?
Old Aug 28, 2019 | 02:23 PM
Nytetime6's Avatar
Check the radiator reserve tank cap. Its plastic and sometimes they crack.
Old Aug 28, 2019 | 02:44 PM
2Quik's Avatar
Thanks for the replay, are after market caps decent or should i just go OEM?
Old Aug 28, 2019 | 02:51 PM
Nytetime6's Avatar
OEM, Go to a Honda or Acura dealer, I think they are less than $3
Old Aug 28, 2019 | 04:05 PM
2Quik's Avatar
cool thanks!
Old Aug 28, 2019 | 09:23 PM
t-rd's Avatar
The cap is about $16, certainly not $3.
Old Aug 29, 2019 | 09:41 AM
Nytetime6's Avatar
The reserve tank cap is $2.05.
https://www.oemacuraparts.com/oem-pa...QtYXV0b21hdGlj
Old Aug 29, 2019 | 11:45 AM
y'all talking about different things
reserve tank cap versus radiator cap
https://www.oemacuraparts.com/oem-pa...dXRvbWF0aWM%3D
Old Aug 29, 2019 | 11:47 AM
Nytetime6's Avatar
Yes we were talking about the reserve tank cap, not the radiator cap.
Old Aug 30, 2019 | 01:41 PM
Gas's Avatar
Gas
3rd Gear
THe exact same thing is happening to me now. I found the reservoir tank cap was cracked. Replaced it but it is still spilling a little bit of coolant. It could be because of the small black sealant around the cap that's missing now. Did you figure out the problem?
Old Aug 30, 2019 | 01:58 PM
Russ M's Avatar
Had the same issue. Turned out my radiator cap had broken. Yes, the spring popped off and everything.
Old Sep 3, 2019 | 08:10 PM
t-rd's Avatar
That's why I said $16 for the radiator cap. The overflow tank has no pressure and does not cause a blowout like that. It's the radiator cap that failed which didn't let coolant into the overflow tank, but out the radiator's neck itself instead.
smsTL
Jan 3, 2018 01:05 PM
paperboy42190
Dec 23, 2014 03:16 AM
fatty
Sep 10, 2009 08:52 PM
duvaL32TL
1G TL Problems & Fixes
Feb 5, 2007 06:25 AM
GreenTL99
Sep 3, 2006 09:57 AM
