Clutch Question
Old Nov 13, 2015 | 04:48 PM
CG's 3GTL's Avatar
Clutch Question
Hey guys so Ive got a question about the clutch.
Ive had the Clutch replaced, slave, and master was replaced as well.
The clutch engagement is fine, however its the clutch pedal itself that I have the issue with, it is back to doing what it was doing before I did all these things, when the pedal is depressed going to the floor or coming back out it makes this strange noise and does effect the fluent motion of the movement going in and out.
Before the clutch was replaced, I had the transmission serviced and the issue went away and then came back, I had the clutch replaced "bad pressure plate" and all mentioned above and now the issue has come back.
What causes this and how to I fix this super annoying issue? Ive read looking for answers and nothing is specific towards this question
Old Nov 13, 2015 | 05:23 PM
MarcDavidoff's Avatar
Do you know if they installed the updated clutch master cyl? I believe it ends in a04
Old Nov 13, 2015 | 07:19 PM
mtiaz's Avatar
Is it a croaking noise?
Old Nov 14, 2015 | 12:28 PM
CG's 3GTL's Avatar
Its a croaking or popping noise.
Im not sure what version MC they used
Old Nov 14, 2015 | 02:00 PM
The original ones ended in A03 and had a TSB for creaking and popping
Old Mar 7, 2016 | 10:47 AM
CG's 3GTL's Avatar
Is this the one you are recommending to get?
46920-S7A-A04
Old Mar 7, 2016 | 11:44 AM
DMZ's Avatar
DMZ
Head a da Family
Got that TSB # and perhaps a link?
Thanks!
Old Mar 7, 2016 | 11:59 AM
CG's 3GTL's Avatar
Very similar issue here: https://acurazine.com/forums/perform...cement-894268/
Old Mar 7, 2016 | 06:31 PM
46920-S7A-A04
Yes although it looks like it is a '5' not an S. It in the TSB link below
Thanks!
Here you go
Acura (Honda) Workshop Manuals > TL V6-3.2L (2004) > Transmission and Drivetrain > Clutch, M/T > Clutch Hydraulic System > Clutch Master Cylinder > Component Information > Technical Service Bulletins > All Technical Service Bulletins for Clutch Maste
LipJones
Apr 25, 2016 10:33 AM
copmagnet82
Nov 5, 2015 01:17 PM
lians60
Oct 27, 2015 10:07 PM
KingBattle
Oct 19, 2015 04:55 PM
MilanoRedDashR
Oct 18, 2015 01:06 PM
