Clutch Question
Clutch Question
Hey guys so Ive got a question about the clutch.
Ive had the Clutch replaced, slave, and master was replaced as well.
The clutch engagement is fine, however its the clutch pedal itself that I have the issue with, it is back to doing what it was doing before I did all these things, when the pedal is depressed going to the floor or coming back out it makes this strange noise and does effect the fluent motion of the movement going in and out.
Before the clutch was replaced, I had the transmission serviced and the issue went away and then came back, I had the clutch replaced "bad pressure plate" and all mentioned above and now the issue has come back.
What causes this and how to I fix this super annoying issue? Ive read looking for answers and nothing is specific towards this question
Very similar issue here: https://acurazine.com/forums/perform...cement-894268/
Yes although it looks like it is a '5' not an S. It in the TSB link below
Here you go
Acura (Honda) Workshop Manuals > TL V6-3.2L (2004) > Transmission and Drivetrain > Clutch, M/T > Clutch Hydraulic System > Clutch Master Cylinder > Component Information > Technical Service Bulletins > All Technical Service Bulletins for Clutch Maste
Here you go
LipJones
04-25-2016 10:33 AM
MilanoRedDashR
10-18-2015 01:06 PM
