Check Starting System
Old May 25, 2012 | 02:58 PM
Onyx97's Avatar
Had an issue the other night, drove the car about 10 miles to the Chipotle. Got out went inside for about 15 minutes. When i came out the car wouldn't start, I put the key in and all accessories came on with no problem turned the key and nothing. There was no response from the starter at all. The MID displayed check starting system. I tried a couple more times and nothing then after about 5 minutes it started up like nothing ever happened. There were no warnings about the starting system anymore and everything worked fine. Drove the car around today and it started each time normally. Anybody know what could have happened? I plan on taking it to the dealer to have the system checked but I want a heads up on what it may be before I go.
Old May 25, 2012 | 04:18 PM
KJ TL-S's Avatar
On my 05 TL, before the starter totally died on me one day, I had a few times when I would turn the key, nothing, turn the key, nothing, and then the next time it would start up totally normally. Nothing ever showed up on my display, but maybe it didn't have that message back on the 05s, not sure what year yours is. But eventually the starter did totally die and need to be replaced. After that, no more issues. IIRC, mine happened at around 75K.
Old May 25, 2012 | 04:51 PM
Azndjay's Avatar
MV612
tap on the starter with a hammer lol
Old May 25, 2012 | 06:27 PM
KJ TL-S's Avatar
^^^That's exactly what got me home with the last bit of life on that starter. Tried doing the same thing when I got home and it didn't work. Changed the starter in my garage the next day.
Old May 25, 2012 | 08:11 PM
Acura_Dude's Avatar
David_Dude
I didn't even know you could still do that. Good thing it worked and you made it home. Sucked that it died though.
Old May 25, 2012 | 10:40 PM
KJ TL-S's Avatar
I was just thrilled that I didn't need a tow truck to get home. I didn't know about the trick either, but my manager called his friend who is a mechanic and asked what we could do. So we found a long metal flashlight in his car, and right as he hit it with the flashlight I turned to key to start it and it worked. That was the very end of the starter tho. We tried the same thing a couple times when I got home to no avail.
Old May 26, 2012 | 08:45 AM
Onyx97's Avatar
Looks like I'll be changing the starter. Is it hard to do?
Old May 26, 2012 | 09:15 AM
akash4u's Avatar
Hammer trick worked for me on a 94-jeep and a 99-camry before. Glad it worked for you once on the TL :-)
Old May 5, 2015 | 08:30 AM
williethekid's Avatar
Willie
my 2007 acur TL WILL NOT START MESSAGE: CHECK STARTING SYSTEM. CAR WORKED LAST NIGHT POWER IS ON, BUT WILL NOT START
Old May 5, 2015 | 10:02 AM
erg69's Avatar
Are you asking for help, or just letting us know?
Old May 5, 2015 | 10:08 AM
How do you know battery 'seems to be okay'
check starting system is usualy battery starter or alternator.
I'd check in that order. Does it crank?
Old Jun 5, 2016 | 11:56 AM
honda's Avatar
7th Gear
In my case all 3 checked out fine by the dealer. They suggested to replace the whole computer ($1,200) due to the "know issue".
It does not crank, but if I try 3-5 times, it starts like nothing happened (no delay, cranking, etc.), other than getting the message all the time.
Any other ideas/suggestions appreciated!
I found this old tread, however, if it was discussed recently, please point me to it.
Thanks!
Old Jun 18, 2016 | 09:54 PM
oracion's Avatar
Same issue here with my '07 MDX. Any help/suggestion would be appreciated!
Old Jul 25, 2016 | 02:33 PM
Knighthawkactl7's Avatar
3rd Gear
Check starting system ....
Happened to me a few weeks back and like the rest of you said .... It started up like normal! A few days later happened to me again and i called the tow service because it wouldn't start at all! Tow truck driver arrived and got in the car and put it In (N) Neutral and it started right up! So that's another tip is you are in the position that it won't start after several attempts and minutes! 07 Acura TL Type S knight hawk black
Old Aug 1, 2016 | 05:40 AM
DMZ's Avatar
DMZ
Head a da Family
When this same symptom happened to me a few months ago, it turned out I needed a new battery cable. They have a way of corroding on the inside even though the terminals were all clean.
Old Jun 21, 2017 | 05:16 AM
Townsend Milligan's Avatar
I just had this problem. I put my car in N and it started right up and I haven't had a problem since. Thanks!
Old Dec 17, 2018 | 08:33 PM
CristianHdz's Avatar
Having the Same issue
The same thing just happened to me. Did you end up switching the starter on yours or was their another solution. My TL started perfectly when I put into nuetral and I cant figure out why?
Old Nov 1, 2019 | 07:13 PM
bcarter13's Avatar
This WORKED thank you! Put it in neutral and keep trying that sucker
Old Jan 8, 2020 | 07:07 PM
BOWFISHMK's Avatar
4th Gear
Anyone found the cure for this. Working on Daughters 07 TL and it starts perfectly in Neutral but Check Starting System in Park. Seems to be getting worse over the past couple weeks. I found the “Shift to Neutral” trick and that’s working, but I would like to find the cause and correct.
Old Jan 8, 2020 | 07:22 PM
peter6's Avatar
If it starts only in neutral check the transmission range switch. Especially what is going on with pin #10
Old Jan 12, 2020 | 06:56 PM
BOWFISHMK's Avatar
4th Gear
Great information. I will start here. Thank you!
Old Jan 23, 2020 | 06:32 PM
BOWFISHMK's Avatar
4th Gear
I have replaced the Range Switch, so far so good, with our Intermittent problem may take. A few weeks to confirm the fix. Thanks for the input.
Old Feb 12, 2020 | 09:41 PM
BOWFISHMK's Avatar
4th Gear
After a few weeks since the replacement part installed no more issues. Appreciate the information and guidance.
mark1980
Aug 24, 2021 05:14 PM
BigJLM1
Apr 20, 2014 12:49 AM
harminder247
Jan 18, 2012 03:43 PM
dobroman2001
Feb 8, 2010 10:35 AM
bigman
Apr 6, 2004 09:49 PM
