Check Engine Light Stays On...
Old Sep 9, 2008 | 02:14 AM
pJchulip's Avatar
Exclamation Check Engine Light Stays On...
Hey there my check engine light went on tonight and it just stays on . I've heard that it usually flashes on and off but mine just stays on. Anyone that might know what the problem may be would be greatly appreciated. I dont want to have to take it to a dealer to have it checked if its not needed. Thank you!
Old Sep 9, 2008 | 03:35 AM
01tl4tl's Avatar
you heard what???????????? It should self test on startup then off unless a problem is pressent
just go to autozone or kragen type parts store
They will pull the codes for you for free- report back here with them.
code reader port is behind center piece between seat heat control switches
Engien OFF- Put car in gear to make room to remove cover piece
Do any work on the car recently? year and miles?
Old Sep 9, 2008 | 05:51 AM
240sx acura tech's Avatar
acura master tech
3rd gen obd2 is under the dash by the hood release.
Old Sep 9, 2008 | 07:36 AM
JimiThng's Avatar
similar to PJchulip, my CEL comes and goes (p2631) the PITA part is i cant get it to the dealership WITH the CEL on!!! what to do? i have an '05 TL with 49,5XX i need to get her in pretty soon. is there a way that the dealership can run tests to see what code is being thrown, this is becoming annoying! thanks in advance.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
