Check engine light on: idling issue and car stuttering
Old Apr 24, 2011 | 12:39 AM
Project X's Avatar
This just started yesterday as my car hit 45k miles. My check engine light came for the first time ever. At idle and very low speeds I can feel it shaking. I still have 60% oil life and will check my oil level in the morning.
Any ideas???
Old Apr 24, 2011 | 01:56 AM
jpgayan's Avatar
2007 TL Type-S NBP
Get to the nearest Autozone to pull the codes. This should tide you over until you get to your nearest Honda/Acura dealer to get it properly checked out. Normally I'd say don't worry about it since it's usually just some emissions nonsense causing the light but if you're seeing driveability issues it could be something more serious. Again, minimize your driving until you know what it is and can be sure that you're not doing damage to your car. Good luck, I hope it's a cheap fix.
Old Apr 24, 2011 | 07:24 AM
oneonlywgs's Avatar
The One
Agreed: get the code & go from there.
Old Apr 24, 2011 | 08:01 AM
VQPower37's Avatar
only go get the code if the car still is drivable, but if u feel it struggling a lot i would suggest not driving it as you dont know what parts u may be damaging. at that point u may have to get it towed to a shop or your nearest dealer
but if its just a sensor or something driving it to an autozone to get the code pulled would be no big deal
Old Apr 24, 2011 | 08:12 AM
Project X's Avatar
Yea i was planning to get the codes pulled this morning. Could it be the spark plugs? My car has had no prior issues and always been serviced on time
Old Apr 24, 2011 | 05:29 PM
jpgayan's Avatar
2007 TL Type-S NBP
The plugs are designed to last 105k miles plus some so it's highly unlikely that they're worn out at 45k unless the car spent it's whole life running around town at redline. Hopefully it's something simple like a bad sensor that caused the ECU to go into "limp home" super rich mode. Minimize driving it and drive like a grandma in a Lexus until you get it figured out. Sometimes a small cheap part failure leads to big expensive failures if left untreated.
Old Apr 24, 2011 | 06:18 PM
Project X's Avatar
I went to auto zone and they pulled the codes it said faulty EGR valve/sensor and recirculation of exhaust.
The EGR sensor at auto zone costs 73 bux. All the mechanic shops and dealerships were closed today so I'll need to get this fixed tmrw. I'm not gonna drive my car a d only drive it to the shop which is not too far.
Question - how much would this cause to get fix and is this a common prob? Also will I cause prob to my car if I drove it?
Old Apr 24, 2011 | 09:05 PM
nfnsquared's Avatar
Don't buy a new EGR valve. Pull the valve and blow it out with compressed air. You probably have a foreign object sticking it open. Simple fix, two bolts and a connector to get it off. Look in the Garage, there is a DIY for this.
Or do a search for "EGR valve". Use the quotes for you search term.
Old Apr 25, 2011 | 09:24 AM
Project X's Avatar
ok ill look into this. will i cause damage to my car if i drive it with this check engine light and EGR related issues?
is the EGR valve easily accessible?
thanks
Old Apr 25, 2011 | 09:49 AM
Project X's Avatar
have the same issue. Dealer wanted to charge 310 and my mechanic was going to charge me 55 for labor but the part itself is 75 bux.
Do we need to remove the engine cover (Platic cover with Acura emblem) in order to get to the EGR valve?
Old Apr 25, 2011 | 09:51 AM
yes, you'll need to take off the engine cover.
two bolts and a wire connector.
15 min job.
Old Apr 25, 2011 | 09:57 AM
Project X's Avatar
will compressed air be enough - i see some ppl use a carb cleaner too..
also will the check engine light go away automatically?
thanks
Old Apr 25, 2011 | 10:00 AM
thanks
we dont know the extent of the clogged valve.
compressed air should get rid of anything clogging it, but in case of a stubborn piece of carbon, you could spray carb cleaner.
Old Apr 25, 2011 | 10:49 AM
nfnsquared's Avatar
Good grief dude, make a little effort to use the resources provided in this forum: the Garage (aka Service Dept) and the search function.
https://acurazine.com/forums/3g-tl-problems-fixes-114/119-diy-egr-replacement-770698/
Old May 21, 2011 | 07:04 AM
07TLTYPESex's Avatar
DANSOLOW
This morning My car would randomly die at idle, and i read this and cleaned the egr valve, boy it was filthy, and the car idles fine now, but I notice a decrease in power now.. Should I use carb cleaner? Replace it? My car just hit 70k miles... Please and thanks for help
Old May 21, 2011 | 05:43 PM
I hate cars's Avatar
Ah, nevermind. I see the direction this one is going.
Old May 21, 2011 | 08:33 PM
DANSOLOW
Power has been restored lol all good now!
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
wusty23jd
Sep 24, 2015 11:41 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Papa Roe
Sep 1, 2015 09:41 PM
