Check Engine Light Flash
Old Aug 26, 2011 | 07:49 PM
redping3's Avatar
9th Gear
Hello!
I have a question concerning the acceleration of my 2004 TL:
Whenever I accelerate full throttle from a low speed to about 60 MPH, the car begins to flash the picture of the engine. I immediately release the acceleration and coast; the light stops flashing when I go do to about 25 MPH.
Has anyone had a similar experience, or a clue as to what could be the problem? It's annoying to second-guess myself whenever I'm doing any spirited-driving.
Thank you!
Old Aug 26, 2011 | 08:14 PM
Hi speed's Avatar
runnin a little boost
Sounds like the engine is misfiring. This can be caused by a bunch of things. I would try to pull the code and go from there.
Old Aug 26, 2011 | 08:34 PM
redping3's Avatar
9th Gear
Will it create a code even though the light isn't permanent?
Old Aug 26, 2011 | 08:55 PM
fabricator's Avatar
honda vehicles store temporary and permanent dtc's (diagnostic trouble codes) definately need to have the codes pulled to go further, misfire, egr issues, a number of things could be the culprit
Old Aug 26, 2011 | 09:01 PM
redping3's Avatar
9th Gear
Ok, thanks!
Old Aug 26, 2011 | 09:50 PM
nfnsquared's Avatar
Originally Posted by redping3
Hello!
Thank you!
There is at least one tsb for 04/05 for this. (MIL under hard acceleration. The ECU was falsely sensing misfire under hard acceleration and needs to be reflashed). Take it into the dealer or call them and see if the TSB has been applied.
Old Aug 27, 2011 | 02:14 AM
redping3's Avatar
9th Gear
Thank you for the insight. Given it's a TSB and not a recall, do you think it might be expensive?
Old Aug 27, 2011 | 06:59 PM
nfnsquared's Avatar
If they won't goodwill it, they will probably charge you for .5 hour labor. It's a 15 minute procedure: plug in the HDS, hit a couple of keys and it's done.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
