Check Engine Light - Error code 2138
Old Aug 24, 2009 | 10:46 PM
beg_luck's Avatar
3rd Gear
Please help. I was at a stop light a few weeks ago and when I started accelerating, I notice my car would hesitate and the CEL and the exclamation with the triangle light would go on. I pulled over, restart the engine and only the CEL stays on and the car drives ok. The CEL would go away after driving 10-20 miles. It happened again today. I went to Autozone and the guy pulls a code 2138 - Failed APP Sensor and a P2197. Has anyone had this problem and what did you do to fix it?
In case anyone asks, I use only 91 octane from Shell and I make sure my gas cap is tight after I refill. At first, I thought this may be the problem but it wasn't.
Old Aug 25, 2009 | 06:28 AM
Turbonut's Avatar
Here's some reading on the code P2138:
https://acurazine.com/forums/3g-tl-problems-fixes-114/acceleration-failure-while-driving-726039/
https://acurazine.com/forums/3g-tl-problems-fixes-114/malfunction-indicator-light-p2138-644042/
https://acurazine.com/forums/3g-tl-problems-fixes-114/check-engine-p2138-640428/
P2197:
https://acurazine.com/forums/3g-tl-problems-fixes-114/running-rough-711322/
https://acurazine.com/forums/3g-tl-problems-fixes-114/p0171-code-710301/
http://www.in.honda.com/Rjanisis/pubs/SB/B04-016.PDF
If it's under warranty take it to the dealer.
Old Aug 25, 2009 | 08:37 PM
beg_luck's Avatar
3rd Gear
Thank-you very much. I hope this will fix my problem.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
