Changing cables to fuse box from battery - really $140
Old Jul 10, 2015 | 01:52 PM
tl07-donnoyet's Avatar
6th Gear
My car was not starting every once in a while - so was jump starting the car and it worked every time. Tired of jump starting i decided to replace battery and the Oreillys guy replaced battery and one connector as it was badly corroded.
Next day the car didnt start again and jumo starting did not work and hence had it towed to the shop.
The guys spends an hour and looks and tellsme the cable from battery to fuse box is corroded and asks me to pay $140 in palo Alto , ca. he might be rigt in replacing the cable-but is $140 reasonable??
Thanks,
Old Jul 10, 2015 | 03:16 PM
erg69's Avatar
If this is the cable you need, then no. $140 is not reasonable.
2004-2006 Acura TL Battery Cable - Body Electrical - Genuine, Positive 04-06 TL Battery Cable - 17777-01210214 - PartsGeek
Old Jul 10, 2015 | 03:20 PM
6th Gear
looks like its only the cable he is changing - i guess the rest is palo alto zip code auto repair costs...
Old Jul 10, 2015 | 05:11 PM
Will Y.'s Avatar
Registered but harmless
If the price is for both the cable and labor to install, then it is reasonable-- it's more work than just a couple of bolts.
Old Jul 10, 2015 | 10:45 PM
jimmyfu's Avatar
It doesn't look too bad to change the positive battery cable. Here's the DIY:
https://acurazine.com/forums/second-...le-diy-880996/
Old Jul 11, 2015 | 09:28 AM
nfnsquared's Avatar
Agreed, totally reasonable IMO.
Old Jul 12, 2015 | 09:50 AM
flyromeo3's Avatar
totally reasonable unless the work is being done for free
Old Jul 13, 2015 | 11:49 AM
Jackass's Avatar
I think I paid Acura $180 to replace mine, so $140 sounds pretty good. If you are handy, you can probably do it yourself. Mine was already sitting at the dealership with a broken cable and I didn't want to drive it 25 miles home hoping it made it.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Aleax
Sep 11, 2015 11:31 AM
bymotion
Aug 31, 2015 05:00 PM
