Car wont start????
Old Sep 25, 2011 | 05:13 PM
Joelito2983's Avatar
Dominic@n TL
Car wont start????
Ok so I just came from a 100 mile trip and when I get to my freinds
House I park the car normally....when I leave the house like 5 mins later the
Car doesn't want to start now .....any help is apreciatted on a quick fix....
Old Sep 25, 2011 | 05:14 PM
combat mediC's Avatar
will your accessories come on?
Old Sep 25, 2011 | 05:17 PM
CLtotheTL32's Avatar
Remove the plastic cover over the battery and make sure there isn't any corrosion around the terminals.
guitarplayer16's Avatar
Need some more info to help narrow down problem.
Does the starter crank? Any sounds? Any power?
Thanks =)
Old Sep 25, 2011 | 08:26 PM
Dominic@n TL
Ok so I cÀlled my freind that installed the alrm....everything in the car works perfectly It just didn't want to start.....when he came it started after a couple of trys...and when it started the check engine light came on....from his guess and what I thought also is that the car was not reading the key codes but I was surprised that the car remote start didn't want to start either
Old Sep 25, 2011 | 10:21 PM
eduthesamurai's Avatar
whoa thats crazy. not reading your key codes? but then it started. how about now. does the car start normally now? does it gives you any problem after that event?
Old Sep 26, 2011 | 07:34 AM
Dominic@n TL
The car starts but i still have the check engine light on so since i am at work my brother is gonna take it to the mechanic to check the error code that it has so i can know for sure what is really wrong
Old Sep 26, 2011 | 09:51 AM
Dominic@n TL
Ok so i ended up taking the car to the mechanic and just for my luck i got there with the check engine light on ...parked the car until i was gonna be attended ....when there were gonna do the diognastic test to the car all of a sudden the car didnt have the light on ....wtf????
They still conected the computer and apear that the oxigen sensor and the trans. sensors were pending problems but after that nothing else ....
They told me that if the check engine appears again to take it straight to him so he can check it again.
Old Sep 26, 2011 | 09:53 AM
the codes are stored....
so if the CEL goes off, it still throws that code.
it would have been very helpful if you posted what codes you received as 02 sensor and trans is very very broad.
Please post the exact codes.
Go to an auto parts store to get the codes read
Old Sep 26, 2011 | 09:59 AM
Dominic@n TL
Sorry i was to busy on my work phone that i let my freind just do the diagnostics ..and eventually cleared up all the codes ..as he told me but if anything problems persist again ima make sure to right down the codes.
Old Sep 26, 2011 | 10:02 AM
^hopefully we can get to the bottom of your troubles
saberlove
Mar 11, 2021 09:29 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
