Car barely wants to start!
Old Feb 2, 2010 | 12:42 PM
jonathan05's Avatar
ok so when i start my car it seems like it doesnt want to start. i have to press on the gas pedal then itll start. new battery. can someone help me?!?
Old Feb 2, 2010 | 12:59 PM
leedogg's Avatar
RAR
maybe u need a new starter/alternator
Old Feb 2, 2010 | 01:53 PM
loojoohnnyl's Avatar
go to advance they can check for free to see if u need new battery, alternator, or starter. i just had mines check yesterday and i needed a new battery.
Old Feb 2, 2010 | 04:11 PM
jonathan05's Avatar
ok i will. i was thinking i need new starter. how much do those run?
Old Feb 2, 2010 | 05:04 PM
Majofo's Avatar
Pressing on the gas pedal doesn't prime fuel like older cars with carburetors. In fact it doesn't do anything at all in a fuel injected dbw vehicle until the car is started. If the battery were dead it won't attempt to turn over, but instead you'll hear clicking. Starters typically sell between $100 - $200.. stay away from Napa starters or starters that are rebranded from China. Best thing to do is to get your battery & your alternator / charging system checked out, they'll test the voltage on the battery then hook up a meter to verify enough charge is being supplied while your vehicle is on. If you only experience this in cold mornings it's more than likely your battery, get a higher rated cca battery.
Also.. if it refuses to turn over and you don't hear the starter spooling.. take a hammer and tap it a few good ones.. it might knock off enough carbon buildup to get it going.
Old Feb 2, 2010 | 05:32 PM
jonathan05's Avatar
ok ill stop by an auto parts store tomorrow and see what is wrong. and ill get back to you guys. hopefully its only a battery.
Old Feb 2, 2010 | 05:55 PM
sixsixfour's Avatar
how many miles do you have? it may be still covered under warranty. my car is in for a warranty fix (passenger seat heater not working) and they did a complimentary battery check. they said my terminals were corroding (weird, i check them each time i wash the car) and they replaced the terminals and the battery under warranty.
Old Feb 2, 2010 | 06:00 PM
jonathan05's Avatar
i have an 04 TL with 67,000 miles on it.
Feb 25, 2020 09:57 AM
BreezyTL
Jul 26, 2016 12:52 PM
bearingman07936
Jan 7, 2016 03:22 PM
ibGTV
Sep 28, 2015 03:40 AM
jordanboi
Sep 5, 2015 01:33 AM
