Cam Plug Leak
Old Oct 4, 2018 | 11:10 AM
Robert Williams's Avatar
4th Gear
Cam Plug Leak
So, im leaking out of both of the Cam plugs. Can someone give me the part number for the OEM oring? Ive looked and cant really find a definite answer.
*Not my photo, just for an example of what im talking about*
Old Oct 4, 2018 | 11:22 AM
Is it part of this gasket kit? https://www.oemacuraparts.com/oem-pa...1hbnVhbA%3D%3D
Not sure to be honest.
Old Oct 4, 2018 | 01:55 PM
4th Gear
It seems like its part of the “thrust cover”? On this diagram I found its #13. I need the oem part number.
Old Oct 4, 2018 | 02:14 PM
YUP , you're right, my mistake
https://www.oemacuraparts.com/v-2006...-cylinder-head
#13 can be found there. 91301-P8A-A00
Old Oct 4, 2018 | 02:35 PM
4th Gear
Okay cool. Because those are the O-rings i already ordered but when they came the receipt said theyre for an Oil pump so i wasnt too sure. But theyre probably just a universal part. Thanks alot.
Old Jan 10, 2022 | 02:07 PM
Big Dom's Avatar
Big Dom
Just replaced an o ring -
Acura (37772-P8A-A01)
Tried this once before but it still leaked.
second time appears to be the charm.
advice - put o ring in freezer for 4 hours to stiffen it. Use a lot of grease on plate and where plate is inserted.
gotta be careful not to pinch or rip the o ring when installing. Freezer plus a sh*t ton of grease!
Old Aug 20, 2022 | 03:41 PM
Big Dom's Avatar
Big Dom
8 months later and seal is leaking again. Not a huge amount....but enough to bother my OCD.
question: if I do this for the 3rd time, I am going to also use some type of sealant or permatex.......unless you good folks talk me out of it. Thoughts??????????
Old Aug 20, 2022 | 05:18 PM
peter6's Avatar
You shouldn't use any sealant on o-rings or rubber gaskets. Only times when I believe in putting silicon on the gasket is if gasket is paper or surface is pitted / damaged from corrosion.
Put some oil, grease, assembly goo on the o-ring before inserting to prevent damage to the o-ring.
Old Aug 21, 2022 | 11:12 PM
redbeard1's Avatar
Originally Posted by Domenic Ricci
Thoughts??????????
Sometimes, a clogged pcv valve will put pressure on oil seals. If you have not had yours replaced, I would check to see if it is still good (takes less than five minutes to remove and check).
https://acurazine.com/forums/third-g...urging-966184/
If your pcv valve is good, look for any scratches on the thrust cover and mating walls. It is possible to scuff the surfaces if you are not careful.
https://acurazine.com/forums/3g-tl-p...l-leak-917513/
Old Aug 22, 2022 | 12:33 PM
Big Dom's Avatar
Big Dom
Thank you for reply. I'll get a new PCV today since it's inexpensive and easy to change.
I have concerns that maybe the thrust plate or surface is scuffed - my mechanic warned me of this too.
My problem is - do I try again for third time or have mechanic do it?
I mean, it's easy to do, but obviously I'm not doing it well / effective.
I used a lot of grease. I put o ring in freezer. I was careful when installing. I took my time. Yet I guess I am not good at this task.......
Old Aug 22, 2022 | 12:40 PM
Big Dom's Avatar
Big Dom
Im not really losing oil on the stick, but it bothers me anyway! Oil leaking down on starter or other parts.......gets hot.....smells!
Old Aug 22, 2022 | 02:21 PM
Big Dom's Avatar
Big Dom
Silicone paste!!
Old Apr 28, 2025 | 12:10 PM
Chad05TL's Avatar
ASMR seal R&R.. I feel all warm and fuzzy now
Old Apr 28, 2025 | 02:19 PM
Chad05TL's Avatar
I just did my front cam cap seal and replaced the temperature sensor. It took longer finding a 12mm socket that was short and not too thick than anything else. I think a 15/32 socket may work ok if you do not have a 12mm.
I did exactly like like the Video with a few exceptions.. (The EGR comes off really easy).
After I removed the screws on the cam cap, I tapped the cap around the circle about 1/2 inch or so, just like the video.
But I used a large Hook on the bottom edge to try and pry it out straight.
When reinstalling the cap, I tapped it directly inward on the center of the cap very lightly with a hammer, so that I didnt force the cap in any picular positions and it went it pretty easy. It is not pressed as tight as a ball joint..
I also did not use silicone. I just used a little bit of oil that was already inside the cap. Just use you finger and get it wet, and spread it around the new o-ring.
The old o-ring was hard and didnt want to stretch off the cap. But the new one was very easily to install.
Note: 1 of the EGR bolts is right smack in the way. So I used an extension that has a "Rounded tip" so it swivels. I bought it at harbor frieght. (see pic)
Old Apr 28, 2025 | 03:35 PM
twokexlv6coupe's Avatar
Thanks for the tips.
I bough the o-ring two weeks ago and planning on doing it in the very near future!
devitocoke
Nov 7, 2014 02:59 AM
pits200
Jun 27, 2010 05:25 PM
mr2fast2thao
Feb 11, 2010 01:18 AM
chitownRLer
1G RL (1996-2004)
Jan 7, 2009 09:32 PM
EvolveTSX
Oct 29, 2008 04:58 PM
