Camshaft thrust cover oil leak
Old Sep 7, 2014 | 07:13 PM
t-rd's Avatar
I need an opinion on whether anyone has replaced this before and how to replace it. This is for an Accord V6, engine is almost identical.
The engine has an oil leak from the front camshaft thrust cover on the cylinder head. I know for sure because I took brake cleaner to it a few weeks ago. The oil leak isn't coming from the valve cover, but from the camshaft thrust cover next to the EGR valve.
From the parts diagram, it looks like you can just remove the cover and replace the o-ring inside, part #13 in the diagram (most likely the cause).
Please advise and thanks!
Attached Thumbnails Camshaft thrust cover oil leak-14sda701_e1001.png   Camshaft thrust cover oil leak-thrust-cover-leaking.jpg
Old Sep 7, 2014 | 07:42 PM
mzilvar's Avatar
should be a really easy fix once the EGR is off unless anything else is in the way, just 2 bolts and an O-ring
just don't score it and make sure the o-ring is relaxed in it's seat or it gets thinner (if its stretched or twisted)
probably going to have to use something like a gasket scraper to wedge between the head and the end cap at the seam and pry it off a little at a time from one side and the other
odd to see a leak there
Old Sep 8, 2014 | 08:09 PM
t-rd's Avatar
It looks easy, but the question is whether I'll mess with the existing position of the camshaft?!?
Old Sep 8, 2014 | 09:22 PM
mzilvar's Avatar
that cam isn't going to budge, it's got the cam pulley on the other end it's not going anywhere, the thrust cover just pops into the end of the cylinder head just like in the picture it isn't attached to the cam or anything
Old Feb 19, 2018 | 11:12 AM
redbeard1's Avatar
Just did this repair. It seems like a rare problem, but my car was definitely leaking there.
Only hard part was getting cover off without scoring inside cover. The cover was wedged in tight and I did not want to put a small screwdriver between the mating surfaces as was suggested by the poster in the attached picture.. I finally succeeded by using a small vice grip on the bolt hole (contact area marked A and B). I made sure the vice grip did not touch the inside mating surface and 1) pull a little 2) move grips to the other side 3) pull a little 4) repeat 15x.
Old Jan 18, 2019 | 02:54 PM
mattcl-s's Avatar
how's it holding up any leaks so far I would like to know mine is leaking from the same exact spot thank you
Old Jan 18, 2019 | 03:32 PM
It's an easy repair. The O-ring part # is 91301-P8A-A00 for your CLS6. Slime the o-ring heavly with oil before reinserting the cover back into position. Moving gently while applying pressure. Make sure you don't over tighten the two cover bolts into the head when reinstalling, no more than 16lbs-ft.
Old Jan 18, 2019 | 04:39 PM
redbeard1's Avatar
Repair has held up well. The old o-ring was flat.
Be careful removing cover (IMHO, do not pry between mating surface).
Also, as others have written, be careful putting cover back. Don't rush or the o-ring could get caught between mating surfaces.
Old Jan 19, 2019 | 03:33 PM
mhtut83's Avatar
I think mine is leaking as well. Thanks for posting the Part # of the O-ring.
thegipper
Oct 21, 2015 07:19 AM
IIDXholic
Oct 8, 2015 07:53 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
winkyyy
Sep 11, 2015 04:40 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
