A/c smells/stinks
Old Jul 25, 2009 | 03:53 PM
davewhodavedunn's Avatar
A/c smells/stinks
SORRY THIS WAS IN THE WRONG SECTION....
When I turn my ac on a stinky smell( LIKE OLD COFFEE) comes from it, and same when I turn it off, eventually it goes away but I dont know what this could be, it's so weird. My honda accord was like this too...
my tl is a 2006
Any suggestions?
Old Jul 25, 2009 | 09:01 PM
PhilB81's Avatar
I think that's moisture from the ac that's molding.
Not sure how to easily fix this
Old Jul 25, 2009 | 09:18 PM
hmmmmmmmmmmmmm anyone know how to fix?
Old Jul 26, 2009 | 04:17 AM
fillabuster's Avatar
3rd Gear
I've heard that spraying a generous amount aerosol lysol into the A/C intake (not to be confused with the engine air intake) will help with this (unsure if this actually kills the mildew or just covers up the stink).
I've also heard that blasting the fan (without the A/C) before turning off your car helps move the moisture out of the vents and helps prevent condensation (which results in mildew).
Old Jul 26, 2009 | 06:23 AM
SouthernBoy's Avatar
Registered Member
Here's how to prevent it.
Don't select the recirculate mode, use the AUTO mode and let it do the selection for you. Also, a few miles before you get to your destination after having used your A/C for a bit, turn it off, set the vents to dash (voice command), set the temperature to "Lo", and let the fan run at the highest speed. This will help in drying out your evaporator. Do these things and you will not get the moldy odor.
Old Jul 26, 2009 | 11:37 AM
Will Y.'s Avatar
Registered but harmless
Originally Posted by davewhodavedunn
my tl is a 2006
Any suggestions?
Has the cabin air filter been changed yet? If not, change it and remove any debris from the housing and all vent openings.
Old Jul 26, 2009 | 12:10 PM
Majofo's Avatar
+1.. spray down the vents as well..
Old Jul 26, 2009 | 03:04 PM
PhilB81's Avatar
That's what I try to do as often as I remember, but it's a tuff commitment because it gets hot and humid in a flash without the A/C on.
On the TL I assume the heater core is after the a/c coils correct? If that's true turning the heat up wouldn't help, if it's the other way around it would help it dry up.
You should get a turbo timer and set it to 2minutes and let the fans blow full blast when you leave. We used to do that in my cousins car.
Old Jul 27, 2009 | 12:22 AM
I doubt the guy who own my tl ever changed the cabin air filtre, but I can't located it and for some reason my car didnt come with a manual...where is the cabin air filtre located? and where these tube located to spray down?
Old Jul 27, 2009 | 01:32 AM
Will Y.'s Avatar
First, the 3G Garage has links to all sorts of threads, including cabin filter change threads with photos, here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-service-department-aka-garage-questions-answers-check-here-first-553557/
You can order a charcoal filter from Rock Auto, or pick up an OEM non-charcoal filter from the nearest dealer. Several threads have the part numbers for the OEM filters if you want to try a nearby Honda store rather than an Acura dealer.
Section iii of the 3G Garage has links to on-line versions of the owner's manuals and Navi manuals for every Honda/Acura since 1990 here: https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp.
Old Jul 27, 2009 | 05:34 AM
Registered Member
Both of my 3G TL's ('04 manual and '05 automatic) have Navi. If I have only been running it for 10-15 minutes, I tend not to do this. But if it has been running longer, I go through a simple process to begin the drying. Anyway, here is what I do when shutting down the A/C under those conditions.
o If it is in recirculate mode, I turn that off.
o Manually turn off the A/C.
o Issue voice command, "Climate control dash".
o Turn the temperature down to its lowest setting.
o Make sure the fan speed is set to its highest setting.
I do this for maybe 2-3 miles or about 5 minutes, then when I arrive at my destination, I set the fan speed to 2 or 3.
That's it. No odor.
Old Jul 27, 2009 | 12:53 PM
1fsthatch's Avatar
this is why when i smoke a cig or w/e else lol i dont have the ac on....not saying you smoke in your car but i hate when the A/C smells like old cigs
Old Jul 27, 2009 | 05:57 PM
Registered Member
I don't smoke and no one, I mean no one, is allowed to smoke in my cars or my home. I am not an anti-smoking nut (if someone wished to smoke, that's their business). I just have an overly sensitive olfactory sense (you would be amazed at the things I can smell) and will not allow certain things in my domain. I don't even wear after shave or cologne because it gets in my clothes and my car and I can't stand that. I won't even allow my wife to use hand lotion that stinks because she will touch things that I tough (yes, my nose is that sensitive).
Biggie_B
May 27, 2025 05:51 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
hashbrown
Sep 29, 2015 12:13 PM
lovic87
Sep 15, 2015 06:07 PM
dlknight
Sep 3, 2015 07:54 PM
