A/C Compressor Burnt out?!
Old Jun 1, 2013 | 05:53 PM
Lukieluc's Avatar
Angry A/C Compressor Burnt out?!
My A/C stopped working today... The air went from being ice cold to warm in a matter of seconds.
Right before it malfunctioned... I smelt burning rubber and saw smoke coming from the right side of the car. After switching off the A/C and popping the hood I noticed little bits of burnt rubber (or plastic) on the frame of the car under the compressor. Now every time I turn on the A/C the air awfully warm and there's a loud screeching noise. The serpentine belt looks old but doesn't look damaged.
I called Acura and got a quote of ~$900 to replace the compressor. ($350 for labor and $550 for a compressor and 2lbs of freon)
My questions are...
1) Is the compressor burnt out or is the source of the issue another part?
2) Could I purchase a Denso compressor from the website below and have the dealer install it?
http://www.partsgeek.com/catalog/200...ompressor.html
Not sure if it matters but I drive a 07 TL-s with 75K 6spd
Old Jun 1, 2013 | 06:01 PM
YeuEmMaiMai's Avatar
compressor seized and toasted the clutch? I would see if they are willing to pick up part of the repair on that if you have been a good customer
Old Jun 1, 2013 | 06:12 PM
Lukieluc's Avatar
I've never had any issue with the car so I've never been to my local dealer.
So, I'm out $1,000 because of this?!
Old Jun 1, 2013 | 08:40 PM
^ Dealer may not want to install used parts but if they do, no waranty...
Old Jun 2, 2013 | 06:53 PM
Lukieluc's Avatar
Old Jun 11, 2013 | 12:03 PM
Lukieluc's Avatar
Got the car checked at Curry Acura, they qouted me $1,000 for parts and labor. The AC Compressor, clutch, and relay need to be replaced.
Old Jun 12, 2013 | 09:26 PM
^that's not bad, I Just paid $400 to have my condensor and receiver/dryer replaced.
The parts on that build are $500 for compressor and $210 for clutch
Old Jun 14, 2013 | 05:24 AM
dcmodels's Avatar
Did the dealer specifically state that the compressor is seized? or 'burned-out'? or exactly how its damaged?
You may wish to at least read the MDX TSB 11-031 concerning how a bad A/C clutch relay (stuck-on) can cause the clutch itself to constantly run, and the compressor to vent all the Freon, obviously causing the system to no longer provide cold air.
LINK: TSB 11-031: MDX upgraded A/C clutch relay, symptom of Dead Battery and/ or A/C Cools Poorly
https://acurazine.com/forums/showthread.php?t=728064
Biggie_B
May 27, 2025 05:51 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
hashbrown
Sep 29, 2015 12:13 PM
lovic87
Sep 15, 2015 06:07 PM
