Button sequence to reprogram clock?
I installed a Nexus 7 in my dash and - wouldn't you know? - the clock isn't set correctly for daylight savings time. Would someone be kind enough to post the button sequence to do the following:
Much appreciated!
- Turn the clock back one hour
- Turn off automatic daylight savings time
Much appreciated!
Registered Bunny
Much appreciated!
Much appreciated!
Here's how more precisely:
https://support.google.com/nexus/answer/2841106?hl=en
Push up on the setup/info button
Choose screen 4
Choose Timezone/Clock
All this info is in your Navi manual...
Choose screen 4
Yep, no original screen. If you wouldn't mind providing a literal "click this button x number of times, click that button" etc that would be great. Also note that I don't have the use of the joystick - it's wired into the Nexus. I'm not sure if what I'm trying to do is possible using just the right knob or not - I may just have to live with it. Thanks so much!
Not possible without either the screen or joystick AFAIK....
If you know someone that has a HDS, they might be able to do it from there...
soupi
14
11-15-2015 11:15 AM
