Button sequence to reprogram clock?
Old Dec 22, 2014 | 03:19 PM
NebraskaJ's Avatar
I installed a Nexus 7 in my dash and - wouldn't you know? - the clock isn't set correctly for daylight savings time. Would someone be kind enough to post the button sequence to do the following:
  • Turn the clock back one hour
  • Turn off automatic daylight savings time
Much appreciated!
Old Dec 23, 2014 | 09:32 AM
polobunny's Avatar
Registered Bunny
Much appreciated!
You mean on the tablet? Settings > Date and Time.
Here's how more precisely:
https://support.google.com/nexus/answer/2841106?hl=en
Old Dec 23, 2014 | 09:34 AM
I think he means the car itself isnt timed right.
does OP have navi or non-navi?
a simple trick would be to pull the battery cable at lets say 12:00 to match the car with the correct time.
Old Jan 1, 2015 | 01:54 AM
NebraskaJ's Avatar
The car is navi.
Old Jan 1, 2015 | 09:27 AM
nfnsquared's Avatar
Push up on the setup/info button
Choose screen 4
Choose Timezone/Clock
All this info is in your Navi manual...
Old Jan 1, 2015 | 09:50 AM
Choose screen 4
the post doesnt say if he removed the original screen.
womp womp womp
Old Jan 1, 2015 | 12:30 PM
NebraskaJ's Avatar
Yep, no original screen. If you wouldn't mind providing a literal "click this button x number of times, click that button" etc that would be great. Also note that I don't have the use of the joystick - it's wired into the Nexus. I'm not sure if what I'm trying to do is possible using just the right knob or not - I may just have to live with it. Thanks so much!
Old Jan 1, 2015 | 12:58 PM
nfnsquared's Avatar
Not possible without either the screen or joystick AFAIK....
If you know someone that has a HDS, they might be able to do it from there...
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 29, 2015 08:26 AM
thegipper
Sep 28, 2015 01:01 PM
