Broken pinch bolt - Drill out and buy longer bolt?
Old 11-18-2011, 11:32 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Hey
I still have a broken pinch bolt on my front passenger side that holds the shock to the fork mount.
I've tried almost everything to get the bolt out but it's damn stuck.
I was just wondering, can I just drill out the whole bolt (and most likely ruin the threaded side of the fork mount) and just buy a longer bolt and use a nut at the end to tighten the new shock to the fork mount?
I just wonder if it'll be strong enough.
Cliffs:
- Pinch bolt head snapped off
- Wondering if I can drill out the whole bolt which will most likely ruin the threading inside
- Buy a long bolt and put a flange nut to the end of it (essentially converting a pinch bolt design into a classic bolt and nut design)
- Will it work good enough?
Thanks!
Old 11-18-2011, 02:35 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
If you drill it out can't you re-tap/heliocoil the fork for a new bolt?
Or why not just get a new fork for ~$70?
Old 11-18-2011, 02:39 PM
Received 16,263 Likes on 11,973 Posts
^i thought that was the direction you were going to goo?
"if justin had tobuy a new radiator..."
Old 11-18-2011, 02:46 PM
Just trying to save some money lol
I called my Honda dealer the other day and he said it was $81 but he said it was on backorder and it won't arrive until mid-December.
I suppose I can order it online or heads to a junk yard.
Old 11-18-2011, 02:52 PM
^lol, I tried to save money by buying springs instead of coils.
I ended up spending about $700 all together. Yikes.
this included:
shocks
gas money
radiator
and paid time to use the spring compressor.
Old 11-19-2011, 07:08 AM
johnny3's Avatar
Take the fork off & drill the stub out, get a grade 6 or 8 (aircraft quality) bolt & nut that will pass thru there, use a lock washer or double nut it.
Old 11-19-2011, 09:23 AM
Jesstzn's Avatar
Preferably grade 8 fine thread ... anything less can snap.
Old 11-19-2011, 09:25 AM
Thanks guys!
Where can I get a "grade 8 fine thread"?
And I can't take the fork off without drilling the bolt out first because there's a notch at the bottom of the shock absorber that the pinch bolt goes through.
That being said I have to do it the harder way and drill out the pinch bolt while it's on the car.
Old 11-19-2011, 11:51 AM
KN_TL's Avatar
Fastenal's appear to be everywhere these days. They should have them.
I wouldn't do anything short of replacing the fork and maybe using a stronger bolt.
Old 11-19-2011, 11:54 AM
Thanks man.
Damn the closest one is an hour away from me.
I think I'll just "temporarily" use the one I bought at Home Depot that says 8.8 on it (I think that's a grade 5) until I have business in the place an hour away, which is soon lol
cycdaniel
12-17-2019 10:58 AM
james357
02-13-2016 02:37 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
darksky
09-05-2015 03:11 AM
Quick Reply: Broken pinch bolt - Drill out and buy longer bolt?
