Battery Issue
Old Jul 21, 2014 | 05:17 PM
jayroc619's Avatar
Battery Issue
Advise needed...
If my battery is not holding a charge for a day, what could be the problem. I changed the battery and the same issue happened. I went to get the battery and alternator checked and it checked out fine...What could be the problem???
Old Jul 21, 2014 | 05:28 PM
FamilyGuy's Avatar
Something could be draining your battery after you shut the car off. Check your current draw a few minutes after you shut the car off.
Old Jul 21, 2014 | 05:38 PM
Speeden6's Avatar
has your HFL been acting up?
I have had to replace the Alt on mine after 70K, my buddy just had his go out on his type s at 80K.
Old Jul 21, 2014 | 09:33 PM
bauermd's Avatar
If your HFL is having issues, or not responding at all this could be your culprit. It's a known issue to constantly try to connect and drain batteries.
Here is a link to another thread with someone having the HFL battery drain. Could be useful.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/voice-navi-hfl-causing-battery-drain-838605/
Old Jul 22, 2014 | 12:06 AM
A SiQ TL's Avatar
Yea, the HFL was the major cause of my battery draining prematurely also.
Old Jul 24, 2014 | 10:31 AM
williecoyote's Avatar
3rd Gear
HFL was draining my battery too.
Look at the roof in the morning when there is dew or condensation on it.
If the roof is dry right over the rear view mirror area, this indicates heat from the HFL, which means that it is working when the car is off.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
scionxb3003
Sep 14, 2015 01:52 AM
whitesoxsfan12
Sep 13, 2015 02:09 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
