Bank 1 Sensor 2 (CEL CODE P0141)
Old Oct 12, 2019 | 10:48 PM
omzbonez's Avatar
Question Bank 1 Sensor 2 (CEL CODE P0141)
Hey guys,
I've looked around the forum for a quick DIY on replacing the Bank1 Sensor2 02 sensor on the catalytic converter, and found bits and piece here and there. So I got under the car and took a stab at it with Denso 234-4355 in hand I noticed that the wire length is alot shorter than what it should be and doesnt even come close to the connection just under the passenger side of the vehicle. Did i get the wrong sensor? this was the part number referenced in a post on here, so I ran with it. Am I looking in the wrong place? Any help would be appreciated.
OM
Old Oct 12, 2019 | 11:28 PM
peter6's Avatar
Bank 1 is in the rear of the vehicle, that's the one you are looking at right?
Denso 234-4355 is a downstream front sensor. Probably that's why wires look too short.
What car exactly do you have? MT AT, which year?
For DIY - there's not that much to it. 22mm wrench or oxygen sensor socket, most likely a torch, unscrew old one, put new one in.
Old Oct 13, 2019 | 12:02 AM
omzbonez's Avatar
Yeah it the one that is in the rear of the vehicle and comes up and connect up under the passenger side seat. Its a 2005 Acura TL, AT.
I figured the DIY was pretty straight forward, but not if i have the wrong part. Do you have the Denso part# for this CEL CODE?
The code says exactly this "P0141 O2 Sensor Heater Bank 1 Sensor 2"
Old Oct 13, 2019 | 09:15 AM
peter6's Avatar
OEM part number should be 36542-RCA-A01.
Denso part should be 234-4368. Wires are 21 inches long
Old Oct 13, 2019 | 02:49 PM
omzbonez's Avatar
awesome, that looks like the right one. Appreciate your help
Old Feb 3, 2020 | 03:14 PM
Gaspar74's Avatar
9th Gear
Sorry to dig up old thread. . I’m getting error code P0137 sensor circuit low bank 1 sensor 2.
I just need to know if indeed this is what I need Denso 234-4368. I have an 05 TL AT
thanks!
Old Feb 3, 2020 | 10:25 PM
peter6's Avatar
Looks to be the correct sensor if one believes in description at rockauto.
mayjarjar
Jan 14, 2019 06:12 PM
onlydoug
Jan 9, 2014 08:36 PM
stumarsyd
1G TSX Problems & Fixes
Feb 21, 2012 09:01 PM
rvmeush
Mar 13, 2008 06:35 PM
ussi
Jun 14, 2007 06:55 PM
