Auto window up/down not working, even after reset
Old Sep 14, 2018 | 09:43 AM
NTP66's Avatar
2024 TLX Type-S
I spent a lot of time searching for this, and haven't found a fix as of yet.
I had a shop replace the front passenger window motor/regulator assembly [OEM Acura part] on my 07 TL-S. The window now rolls up and down, which it hasn't done in years, but the auto-up/down function isn't working. I have tried resetting this using both methods I've found here - hold down the button, keep holding for 2-5 seconds, then hold it up, keep holding for 2-5 seconds, and the official Honda method that is 120 steps long. Neither has resolved the issue for me.
I don't know if this is related, but if I hold the window button (up or down), a few seconds after the window has fully opened or closed, it sounds like the motor or regulator clicks once or twice, and I swear I also hear something like the tapping of glass. It's consistent, and only happens on this new motor/regulator.
Anyone have any other ideas? I was going to have the dealership run the HSD tool to reset the auto up/down function since my car will be there for an oil change in a few weeks, but now I'm worried if there's another issue going on.
Old Sep 14, 2018 | 10:01 AM
NTP66's Avatar
2024 TLX Type-S
I should add that immediately following the procedure of holding the window button for 2-5 seconds after opening/closing, the window will not open/close the next time I press the button, like it's locked. The next/second time I press the button, the window moves freely again and continues to do so unless I go through that procedure.
Old Sep 14, 2018 | 11:51 AM
Take it back to the shop and have them diagnose/fix it..
Old Sep 14, 2018 | 11:57 AM
NTP66's Avatar
2024 TLX Type-S
I already spoke with them, and they have no issue looking at it again. I'm asking for my own benefit, because I do work on my own car for most other things.
Old Sep 14, 2018 | 02:03 PM
BreezyTL's Avatar
Pull the panel and see if they have everything hooked up.
Old Sep 14, 2018 | 02:31 PM
then just watch them to see what they did wrong
Since someone else did it and is offering to fix it, I wouldn't mess with it else risk them denying to fix it because 'someone else touched it first'
Old Oct 9, 2018 | 02:41 PM
NTP66's Avatar
2024 TLX Type-S
Just to update this thread, I wound up taking my car to Acura so that they could run their tool against it. They told me they couldn't even see an option to reset auto up/down, and concluded that it was likely a third party motor/regulator. So, I called the shop that installed it, and they took a look at it today. It's definitely OEM (they actually purchased it from my dealership, which made me laugh), and were able to get auto up/down working via their own damn scan tool. Why Acura was unable to do this is beyond me. However, it only works using the scan tool; the switch doesn't work. They called Acura (not the dealer) directly and were told that the issue is the master switch in the driver's side door, and that they sell 1-2 of them per day. I'm not paying $210 for that, but am willing to spend $30 on a used one on eBay just to see if it resolves my issue.
dubz ASPEC
Jun 3, 2025 08:48 PM
KB1Spec
Jul 28, 2018 07:54 PM
broly
Jul 23, 2017 04:56 PM
danw
Jul 18, 2008 04:11 AM
BlueCLS6
Feb 2, 2003 02:57 PM
