Auto Window up and down not working
Old Mar 19, 2007 | 11:43 AM
KB1Spec's Avatar
I was up this morning to go to work and noticed that when I press down the driver side window it won't go down automaticially. Then I try the passenger side with the driver side window switch, it is not doing the same thing too. Then I try the window switch on the passenger side, same thing.
Is there a fuse that I blown for the Auto window up and down switch? Hope someone here can troubleshoot this
THanks!
Old Mar 19, 2007 | 07:06 PM
260 HP's Avatar
Did you just replace or disconnect the battery? If you did, the power window's auto function is disabled. To re-enable them do this:
-start the car. push the power window buttons to open the windows.
-pull the buttons until the windows close all the way and hold them for another 2 seconds or more.
See if it helps. If not, it's probably time to visit the dealer.
Old Mar 19, 2007 | 07:26 PM
KB1Spec's Avatar
Yes, I had my battery disconnected because I was fixing my DVD player.
I will try to solve that problem tonight. Thanks for your help!
Old Mar 19, 2007 | 09:45 PM
KB1Spec's Avatar
260HP, just to let you know I got it to work. Thanks for your help again!
Old Jul 5, 2007 | 01:04 PM
ililillilillilil's Avatar
i'm having the same problem, driver's side auto up/down doesn't work. how did you get it to work again??
Old Jul 5, 2007 | 03:49 PM
csmeance's Avatar
Heres how to get it to work in bold
Old Jul 18, 2007 | 05:09 PM
evoman's Avatar
Man i had the same problem with my 2007 TLS! Thanks for that tip!
Old Jul 27, 2007 | 08:50 AM
citidelx's Avatar
RoadRunner
Mine is having the same issue but my battery has not been disconnected. On my car it got stuck being down then being stuck in the up position. I think the window motor in the driver's door is deftective.
Old Aug 7, 2007 | 06:26 PM
citidelx's Avatar
RoadRunner
I took my TLS back to the dealership and they had to replace the motor.
Old Apr 26, 2008 | 02:06 PM
sam the man's Avatar
Thx!!!
I had the same problem and your advice worked thx!!!
Old Jul 11, 2008 | 01:06 AM
firstacuratl's Avatar
邵樂百
Thumbs up I love AZ!!!!!!!
This forum is invaluable for TL owners.....thanks 260 HP.
Old Jul 28, 2018 | 07:54 PM
Mike282828's Avatar
Thanks worked like a charm
TLDude876
Dec 28, 2016 03:18 PM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
asahrts
Sep 4, 2015 05:55 PM
dlknight
Sep 3, 2015 07:54 PM
