ATF Fill bolt Help!!!
Old Feb 23, 2015 | 05:31 PM
iiamchili's Avatar
Hi, so im currently at trying to do a 3x3 ATF change but the fill bolt wont brake loose at the point that the bolt head got rounded, i try braker bar and still the socket just slide. Im thinking to go to the honda dealer 4 min away from home but i think they will charge alot just to brake it loose. Any tips ?
Old Feb 23, 2015 | 05:37 PM
guitarplayer16's Avatar
Don't bother with it.
Mine was too difficult to loosen also, so filled through the dipstick.
Old Feb 23, 2015 | 06:45 PM
iiamchili's Avatar
And how many minutes did it take to fill 3 qutz and what did you used ? Thanks for the reply
Old Feb 23, 2015 | 07:30 PM
I fabbed up a straw attached to a funnel.
Took maybe 10 minutes.
Many people use this method also.
Old Feb 23, 2015 | 07:38 PM
iiamchili's Avatar
Thanks im try take it to a shop tomorrow because i order a new bolt but if they charge more then $20 to loose that bolt i will do it thru the dipstick and return the bolt
Old Feb 23, 2015 | 09:33 PM
wilztlxs's Avatar
TLX-S
i had issues a couple years ago removing the ATF bolt too and rounded it a bit, so i bought this to get it off.
Sears.com
i replaced it with with a new bolt and fill through the dipstick exactly like guitarplayer16
Old Feb 23, 2015 | 09:40 PM
thisaznboi88's Avatar
if you have a harbour freight near buy you can buy a strip bolt extractor also. If not that sears one is also good.
Old Feb 23, 2015 | 09:49 PM
vietxquangstah's Avatar
Holy hell what size MM socket did you use to try to remove that ATF fill bolt?
There is no possible way for you to round it off that badly if you used the correct size MM socket.
My ATF fill bolt is a bitch to remove every time but never once has my socket slipped to round it off at all.
It takes several extensions + breaker bar to remove it.
Old Feb 23, 2015 | 10:30 PM
flyromeo3's Avatar
I forgot to place that o-ring that sits on the ATF bolt one time.
That was the last time I was able to get that bolt loose.
Its so seized in there that I broke a 3/8 ratchet attached to a breaker bar trying to get it loose.
I now use the dipstick tube to fill my atf.
Old Feb 23, 2015 | 10:37 PM
iiamchili's Avatar
I was using a 17 mm but i dont know how the heck got rounded so easy
Old Feb 23, 2015 | 11:07 PM
iiamchili's Avatar
Sears.com
Would this make it?
Shop IRWIN 5-Piece Bolt Grip Set at Lowe's
Old Feb 24, 2015 | 12:14 AM
wilztlxs's Avatar
TLX-S
i tried those, they only work on bolts that don't require a lot of torque.
Old Feb 24, 2015 | 03:29 AM
iiamchili's Avatar
I guess ill go to a shop the nears sears is 18 miles away paying few tolls
Old Feb 24, 2015 | 06:12 AM
Adobeman's Avatar
The DVD-A Script Guy
Was it a good 6 point socket? I've wrestled this bolt on my brothers Pilot and finally did get it loose w/o damage but it has to be a good 6 point socket to do it. Not sure why Honda/Acura insist on so much flange surface area on the AT and MT fill plugs. Seems like overkill and makes it really hard to remove them. Same thing with rear diffs too on their AWD models. Real pain.
You sure do seem to be having more than your fair share if issues. Hopefully your luck will start to get better.
Old Feb 24, 2015 | 09:07 AM
ZOMGVTEK's Avatar
That should be no problem to remove with one of those stripped bolt extractors. In my experience they work very well, and you have plenty of access to hammer it on. You'd want to have a replacement bolt on hand so you don't need to put the trashed one back in.
Old Feb 24, 2015 | 11:27 AM
iiamchili's Avatar
I think the socket was the problem =[ i was using hulk power to get it loose and tha modafka didnt even move
Old Feb 24, 2015 | 11:30 AM
iiamchili's Avatar
I just realize theres a harbour freight 17 min away im going over there rite now. That home depot dont seem that good tho
TypeS860
Jan 10, 2026 11:11 AM
tsx_boy
Dec 13, 2019 08:33 PM
Skirmich
Oct 1, 2015 12:59 PM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
