Aftermarket CV Axles
Old Nov 15, 2023 | 07:21 AM
Leedle_UA7's Avatar
8th Gear
Hello!
I have an 08 TL-S 6MT with 169k on it and am experiencing what seems to be the common issue of worn out CV axles. Been having some pretty rough vibration only under acceleration from 55-70, checked the motor mounts and suspension components and everything else seems fine. Neither axle boot appears torn or leaking grease but from what I’ve researched it seems the inner cv joints go bad and create the symptoms I’m experiencing. I was curious if anyone here has had any luck with the axles from RockAuto (Cardone, GSP, APWI) or any other aftermarket brand? Hoping replacing these will remedy the issue as I’m not sure what else it would be. Thanks in advance!
Old Nov 15, 2023 | 12:48 PM
Go through the thread below, it may help:
CV axle fitment question - AcuraZine - Acura Enthusiast Community
Old Nov 15, 2023 | 03:46 PM
jeffstlnote's Avatar
Had the same issue about 2 months ago, mine was in 2nd gear, and a litlle in 3rd. 20-35 mph range. Axles were original oem, car has 121,xxx. I replaced both axles with OEM from www.oemacuraparts.com. Mainly because I am on coilovers and this video and thread convinced me to just go with oem. The video here below flat out addresses this vibration I think you're probably feeling.
Also here is my thread (if it helps or not )
https://acurazine.com/forums/3g-tl-2...ounts-1003466/
Old Nov 15, 2023 | 05:29 PM
Leedle_UA7's Avatar
8th Gear
I appreciate all the info. I called around to a couple dealers and both axles are on back order with no ETA. I emailed Raxles for a quote. If that falls through I guess I’ll just go with GSP as I’ve seen on similar threads those seem to do okay. I don’t drive the car as much except for in the winter now as I primarily ride my motorcycle throughout the majority of the year so I’m not as pressed about aftermarket stuff. Also for clarification, I notice on the catalogue there is a difference between the driver side axles for AT/MT but passenger side is the same for both?
Old Nov 17, 2023 | 06:54 AM
DMZ's Avatar
DMZ
Head a da Family
Haven't been here for awhile, so I thought I'd chime in. Our master star mechanic here in North Jersey, Paul says he's always had problems with rebuilt axles. Check rockauto for the best deals on new ones.
Old Nov 17, 2023 | 08:32 AM
Leedle_UA7's Avatar
8th Gear
That’s what I’m going with, ordered GSP axles this morning. Will find the time to replace them shortly. I appreciate all the info!
Old Nov 17, 2023 | 12:57 PM
whitesoxsfan12's Avatar
I installed the GSP axles a few years ago, no issues so far other than surface rust which is a bit annoying. Raxle quote was $260 for right side axle. The OEM axles have continued to rise in price so I couldn’t justify it anymore
Old Nov 17, 2023 | 06:13 PM
Leedle_UA7's Avatar
8th Gear
From what I’ve read on here GSP seems to be a pretty safe bet; just wanted to verify due to the price difference. Either way, if it fixes the vibration I’ll be happy lol
Old Nov 22, 2023 | 03:12 PM
Robbym's Avatar
Please update us when you get them installed. My 07 TLS auto shakes so bad above 40 with these Napa axles. OEM axles are 260 each side!
Old Nov 24, 2023 | 10:05 PM
Mcgo101's Avatar
Did gsp axles on both of my tls, Install went well no fitment issues, couple scratches on one but just on the shaft coating. Only got 5k on the new set but no problem so far. I've read the half shaft bushing can tear causing vibrations at certain speeds. Might be worth giving that a closer look too. Gl
Old Jan 11, 2024 | 10:27 PM
Leedle_UA7's Avatar
8th Gear
installed them tonight and drove for 45 mins whilst pushing the car a fair bit, runs and drives great after install. Install wasn’t too bad, took a couple hours. Very smooth so far
Old Oct 3, 2024 | 07:26 PM
Javi_Flacko.9's Avatar
Are they still running smooth?
Old Oct 4, 2024 | 05:10 PM
its been 9months since he’s posted and 6 months since he’s last logged in, safe to say he would have complained by now
Old Nov 13, 2024 | 07:47 PM
icoNicck's Avatar
8th Gear
This one got a laugh out of me lol
Old Jun 27, 2025 | 01:00 PM
rockstar143's Avatar
@thoiboi this shit has me considering these aftermarket ones too. OEM is backordered, Raxles is up to $380 the last time Marty quoted me. I already paid $100 just to reboot the ones I had bought from him years ago. I'll take that convo offline with you but you know...
I need to check my halfshaft bushing as well.
Old Jun 27, 2025 | 01:09 PM
GSP or APWI are the most successful aftermarket/rockauto suggestions from other members in the past here so give those a shot..
https://www.rockauto.com/en/moreinfo...440495&pt=2288
I actually don't even see an APWI option for manual so GSP is your only option.. plus for being 70 bucks each.. worth a stab at it ..
@rockstar143
tylertran
Aug 1, 2025 10:02 AM
2GTL84
4G TL Problems & Fixes
Mar 25, 2021 09:52 PM
SuperGreg
May 14, 2018 05:04 PM
SilverJ
Nov 18, 2010 03:50 PM
dave586270
Nov 15, 2010 12:14 AM
