Acura TL '06 does not accelerate after full stop
Old Jul 30, 2013 | 12:09 PM
nayyarmukul's Avatar
Hi All - I guess my Acura TL 06 is developing tranny problem.
Usually it happens in the morning when I leave home for work. I gently go down the street to the first stop sign and after the full stop the car does not accelerate. I switch from automatic to manual and it starts moving. And than I can switch back to automatic and it runs fine. It happen every morning for first 2-3 full stops (stop sign or red light). In addition, for last few weeks I have been experiencing my car jerks when I accelerate from full stop or make turns on intersection.
Any idea what need to be fixed? I would REALLY appreciate your help.
NOTE: I did ODBII scan and got no codes.
Best regards,
Old Jul 30, 2013 | 12:55 PM
aIRpeACE's Avatar
change the ATF first and see how things work.
Old Jul 30, 2013 | 01:14 PM
Dear airpeace.....thanks for your response.
My mechanic changed the transmission fluid 3 times and flush it but no major improvement. Because ODBII didn't give any code he is not sure what could be the possible reason of this issue. Please advise further.
Old Jul 30, 2013 | 02:51 PM
paperboy42190's Avatar
possibly pressure sensors? or the gear position sensor, check this thread out: https://acurazine.com/forums/3g-tl-2004-2008-93/c-037-diy-gear-position-sensor-replacement-aka-transmission-range-switch-892223/
Old Jul 30, 2013 | 02:54 PM
maybe axles?
Old Jul 30, 2013 | 03:17 PM
Dear paperboy42190.....thanks for your response.
I will try to replace "gear postion sensor" and let you know.
Just curios - Do think its a sensor problem? because ODBII scan didn't show any code to my mechanic.
Old Jul 30, 2013 | 06:11 PM
pohljm's Avatar
That happened to my 06 and it needed a new trans.
Old Jul 30, 2013 | 06:31 PM
ouch!
Old Jul 30, 2013 | 06:43 PM
truonghthe's Avatar
well lets hope its not needed a new trans since honda AT is made from glass and design by a bunch of asses.
Old Jul 30, 2013 | 09:31 PM
Acura_Dude's Avatar
David_Dude
Old Jul 31, 2013 | 03:37 AM
well I wouldnt have recommended it if I didnt think it was a possibility. I mean it might be your transmission dying but just wanted to give you some options before shelling out $2000+ for a rebuild. No way for me to know for sure online
Old Jul 31, 2013 | 09:51 AM
Dear paperboy42190.....I am totally agree and really appreciate your help
Old Jul 31, 2013 | 10:25 AM
More info:
I took my car to mechanic yesterday and he saw the car shaft was in bad state. He replaced it and now my issue has been fixed by 80%. (That means - "Car does not accelerate after full stop" is reduced to 2 - 3 times a day as compared to every full stop).
BUT now sometime when I make a full stop at right light it strongly jerks back. It happens approximately after 1 sec when car stopped 100% and idle. I think it happens when car is idle and it tries to switch to 1st gear from neutral. Please advise.
Old Jul 31, 2013 | 10:29 AM
Dear justnspace.....please see my response regarding replacing my car shaft. Is Axle and shaft is same thing in Acura TL 06?
Old Jul 31, 2013 | 02:54 PM
pohljm's Avatar
I really do not believe you did anything to solve the underlying problem. The only way it would have actually been the axle is if the axle was actually broken and not transmitting power from the trans to the wheels. Then it would not accelerate from a stop 100% of the time. You still have an issue with the trans not engaging.
Old Aug 9, 2013 | 07:00 AM
Hi Guys,
Just an update - I had to replace my car transmission to resolve this issue It cost me $2000 (rebuild with 1 year warranty).
I took my car to various mechanics but nobody was able to tell what was the issue. Everybody said I need to replace the trann.
Best regards,
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
kixo
Sep 5, 2015 08:54 PM
LAMike240
Sep 3, 2015 04:35 PM
