5th to 6th Gear Issue
Old Oct 11, 2006 | 08:21 PM
2ManyHobbies's Avatar
All right so I finally have my new TL. I love it- best decision I have made in a while. However I have noticed a peculiar issue. If I am accelerating up past 40-45 mph there is an intermittent issue shifting into 6th gear. It simply will not go in. What I wind up doing after trying to shift into 6th is re-engage 5th gear, then immediately shift into 6th. That seems to work most of the time. If I am up to speed (70-75 mph) going in and out of 6th is not a problem. Just during acceleration. I have been unable to correlate it to RPM, temperature, etc. At a stop, no problem- though it does seem a bit 'rougher' but it is difficult to be sure.
Some thoughts:
Could this be related to the reverse gear solenoid?
Misaligned linkage?
Computer issues?
I called the dealer on Monday- the soonest they could look at it this Friday- with no loaner! They seemed a bit confused about the whole thing and had no ideas.
Did I mention I have only 400 miles on the car? The car drove great when I took delivery. No 6th gear issue.
Thoughts? Thanks!
Old Oct 11, 2006 | 08:54 PM
NC Silver's Avatar
I had a learning curve with that as I hadn't driven a 6 speed before. I don't remember when but early on, knowing "where" 6th was became natural. Now I usually don't shift into 6th gear until at least 60, usually 75. It's a blast running through the gears. Just my .02
Old Oct 12, 2006 | 09:14 AM
CobraGuy's Avatar
I'm guessing you are trying to put it in 6th at too low a speed. What type of rpm are you running in 6th at 40 mph? I'll bet you're lugging the crap out of the engine. I'm not sure you have a problem there.
Old Oct 12, 2006 | 10:08 AM
ndx2's Avatar
6MT & LSD
^I agree. If you look in the owners manual, it has the suggested lowest speed for each gear, and I think 40, 45 MPH is a bit low for 6th. I don't think I've ever shifted into 6th below 55~60.
Even in 5th, the RPM is tad below 2k @ 40 MPH, so I'd think 6th would be around 1500... a bit low, IMO.
Old Oct 12, 2006 | 08:29 PM
Adobeman's Avatar
The DVD-A Script Guy
Yeah, but... that's probably related to drive-ability, emissions and MPG rather than any difficulty in physically engaging the gear. The car may be sluggish and snorting down the road but going from 5->6 should not be overly difficult at lower speeds.
Like NC Silver aid, It may just be getting used to where 6th gear's "gates" are.
Old Oct 13, 2006 | 07:08 AM
Strictly speaking, there is distinct issue with engaging the 6th gear- regardless of MPH, RPM, temperature, etc. Took the car to the dealership last night and went for a test drive with a service rep. To say he was surprised was an understatement. There is definately something binding, preventing me from going into 6th. I will let you know if they find any thing- and if the problem is actually fixed.
Old Oct 13, 2006 | 10:42 AM
jag123's Avatar
I agree with the other's here that your shifting in 6th way too early. I barely ever go in 6th, its a cruising gear. I only shift the car in 6th when I'm going over 75m or more.
Old Oct 13, 2006 | 11:47 AM
Kennedy's Avatar
OMGWTF4THGENTL
I have a similar issue with 2nd and 6th... I attribute it to the Comptech SS. I've found vehicle speed is a factor, although, I'm unsure how.
Old Oct 13, 2006 | 12:20 PM
1995hoo's Avatar
Keep Right Except to Pass
When I first got my TL in 2004 I noticed that the shift from 5th to 6th doesn't seem as straight back as the 1-2 and 3-4 shifts. My brother noticed the same thing when he shifted into 6th the one time I let him drive the TL. It seems to me to be just slightly further to the right , almost like it's a \ shift instead of a | shift (for lack of a better way to describe it). Once I figured that out, I've never had a nother problem shifting to 6th. Try applying a very slight rightward pressure as you shift to 6th, though not so much as to catch the neutral gate, and see if that helps.
Old Mar 8, 2019 | 02:29 PM
Nixon Rivera's Avatar
3rd Gear
Idk about that
After i had the transmission update from the dealer when im flying at 115-120 it stars doing the same thing i wonder if i get a programmer from ktuner and once i take off the governer will it still do it like i said i dint have this issue untill i had the tranmission updste from the dealer and i contacted them about it they just gave me the run around
Old Mar 8, 2019 | 02:38 PM
horseshoez's Avatar
Latent car nut
Wow, a 13 year old thread bump with a post completely out of context with the thread you posted in. Was it really your intention to post in a thread meant for the third generation Acura TL with a 6-Speed manual transmission?
Old Mar 8, 2019 | 05:27 PM
3rd Gear
Well
i was looking at the 4th gen post but some how it got me on this one i have no idea how to delete or change anything on this but i was meaning to put this on the 4th gen tl post
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
George Knighton
3G RLX (2013+)
176
Sep 16, 2016 08:26 PM
justin7779
Dec 25, 2015 10:33 PM
carz0159
Sep 20, 2015 06:11 PM
Mike Bertram
Sep 10, 2015 09:27 AM
