2005 TL Fishtail in snow?!
Old Mar 6, 2019 | 06:58 PM
merekseng's Avatar
6th Gear
Hello all!
I live in Michigan & we have pretty bad winters & this year, my 4Runner sadly broke down due to a rusted frame so I was left with no other choice then take my TL out. I don’t like driving the TL in the snow! But I have too.
So what I am curious about is, when I drive in snow or on a wet roads, I do not get any control. It feels like my rear end is fishtailing.
I just put new tires on, I got an alignment & it still seems to do it.
Any suggestions or solutions will help!!!
Old Mar 6, 2019 | 07:32 PM
winter tires?
Old Mar 6, 2019 | 07:59 PM
merekseng's Avatar
6th Gear
winter tires?
I am currently running winter tires. But I am lowered if that has to do with anything? I don’t think it would?
Old Mar 6, 2019 | 08:44 PM
horseshoez's Avatar
Latent car nut
It could; I drive my TL in the snow all of the time, and even with all-season tires I have no such issues.
Old Mar 6, 2019 | 10:29 PM
csmeance's Avatar
Lowering the car changes the geometry and how the car reacts. If toe is out or the rear springs are not holding up properly it'll cause the rear suspension on one side or both sides to compress too much. It's all tied with the rear sway bar so it will make the other side of the car unstable also causing that fishtail feel. Also how's your camber? Camber + snow don't really help either if the toe is good.
Old Mar 9, 2019 | 04:42 PM
srg818's Avatar
For snow driving I put on snow tires(a must) and drop the tire psi to 30 in the front and 29 for the rear. My car is also lowered and snow driving is not a problem.
Old Mar 9, 2019 | 04:45 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
OP - are you still on OEM size tires? Wider tires are counterproductive in snow. Narrower is better.
Old Mar 9, 2019 | 05:42 PM
jaydubz's Avatar
Chicago winters are almost just as bad as Michigan, never had an issue with all seasons.
Bulldog2
3G RLX (2013+)
Oct 21, 2016 06:57 AM
fresh88
Dec 16, 2014 06:23 AM
lucnex
Jun 24, 2010 04:37 PM
